Yes - the Helix Core espec Steel is one of ethirteen's direct-mount rings built specifically for the Shimano EP8 crank spline (no spider needed, it just bolts straight onto the crank arm), so it's the right family of ring for your Rise M10.is the ethirteen Helix Core e*spec Steel E-MTB Chainring shimano ep8 compatible with orbea rise m10 2023?
Spot on, @skizzian - 32T confirmed, matches what's already fixed in the post above. Cheers for double-checking me on that one.I think the Stock rise M10 came with 32T chain ring? also the ethirteen chain ring comes with a 2mm spacer for either 53 or 55 chainline so chainline should be ok
