mtbross
Got mine from my local dealer.Where do you buy the chain guides from ?. Iv got the 2019 and wanted to fit the 2020
Curious if you have the same result I had...huge.New top chain guide (2020 version) being fitted to my new 2019 C70 Altitude tomorrow and shipped to me later this week. SUPER excited to say the least.
Haven't they changed something for this model year to deal with the noise, sure I read about it somewhere
Yup. 2020 upper slide replaces upper roller.Haven't they changed something for this model year to deal with the noise, sure I read about it somewhere
World of difference. Have noticed I need to take it off to clean every few rides as it builds up with gunk. I also pull the cover next to it and clean cogs in there too. Keeps thing running smooth and quiet.Upper roller replaced with a slide-guide that pivots a little. Def quieter. View attachment 17825
Great bike. Love it.This bike had my curiosity but now it has my attention
Looks like a Levo on steroids
I've ridden gen3 Bosch and Brose systems. Their power delivery is quite different to the PowerPlay. The Dyname motor uses a speed sensor, and a torque sensor that behaves a bit like a throttle. The power modes can be thought of as a power delivery ceiling ie: Eco mode at 40% is variable power added to the rider's input up to 40% max assist. Base power delivery appears to use a pre-set assist level that is related to the selected peak power mode. There is no run-on or power-smoothing. You stop pedalling and it stops delivering. It uses a soft-start feature so no matter the power mode selected, the motor cuts in softly and quickly ramps up. It won't fire you over the edge exiting a berm in Ludicrous mode for example.Got a few questions ... i guess you can’t run a bigger chainring than the stock one right?
And how much powerfull does it feel compared with the “big four” motors? Slightly, noticeable or very noticeable?
So how did you go? I got a similar deal which brought the spend in underneath anything similarly specced from any other manufacturer. Wow did I make the right choice 2000kms + on the bike in 3 months. Amazing bike.OK about to pull the pin on a 2019 Altitude C70. Looks like one of the last Large bikes left in Australia and reduced by $3000 AUD. Seems I cant justify a 2020 bike now especially with the redesign of the chain guide on the RM. A dealer told me today that RM went through 12 different designs before they settled on the one they are bringing in for the 2020 model and can be retrofitted to 2019.
New Guide
Any advice before I go ahead?
That you're a massive internal battery sell out?did you heard that?
Yeah. I hear you.
I always heard you. Despite 90% of your thoughts on geometry and how it affects handling being clueless drivel
#264LYFbro #RideMOAR ?
I feel a lot of love in the room.
How much? Where to order? Is there any other updates? mine is a 2018 c90
Does anybody runs 32t? What the “average” range for the 632wh?
Next week arrives!
What suspension and brake spec does your's have Eddy?Ok I got the bike with me.
Give me a few days to try it and give a better review. My local trails ain’t to demanding and I need to set up a bit the suspension. After that i will do a truly mountain day and I’ll give you my impressions. But yes, the few rides I do it’s feels more like a regular bike than a ebike, even handling while walking to move it (i mean without actually ridin on)feels light, and that’s very impressive. I noticed it requieres less space to turn in my garage than my BH multipla wich is 68.5 slack 51 offset fork and has a 30mm stem ....
Stay tuned
I've ridden 3000km on my C50 so far and still on the original cassette with no shifting problems, although the XT 12speed chain has just hit 0.75 wear after 1800km so the drivetrain is up for replacement soon. It's interesting you find the bike light. Mine is an XL and weighs 24.5kg with pedals.
SRAM Guide RE and Yari Fork, Fox Float Kashima rear ... the previous owner took the Fox 36 for their son bike or some like this, don’t care the Yari can be upgraded to Lyrik Charger, by now it’s ok
Mine it’s a C90 M, claimed to be about 21.5 kilos so its smaller and lighter ... i definitly feel it very light than it is wich is not bad but not the lightest ebike.
I find the Yari fine for what I ride, which is pretty much everything short of double jumps over 16ft. I'd guess your smaller bike will be a little more playful, whereas my XL is basically a KLX250 with pedals ?
I also had gunk build-up issues with mine. I tried a couple of different lubes but for the last 2000km have been using Purple Extreme. I wash the chain in petrol, dry it with compressed air and then apply a drop of PE per roller. Best lube ever. No mess, no build up, doesn't attract crap, and if you allow it to dry overnight after applying to a clean chain, won't wash off in wet either. 2000km on one XT12 speed chain which is just now approaching the end of its serviceable life. Highly recommended for the RM drivetrain.World of difference. Have noticed I need to take it off to clean every few rides as it builds up with gunk. I also pull the cover next to it and clean cogs in there too. Keeps thing running smooth and quiet.
Same mate. I still use the original toothed roller and won't replace til it's shot. I really only notice the noise when I'm riding with friends on their push bikes.The noise doesn’t bother me at all. Is a mechanic sound like the ratchets or some, def less annoying for me than the buzz from a motor. When the time comes to service it I upgrade to the new one but for now is no prob for me at all.
