Levo chainring bolts
  • Thread starter Deleted member 4988
  • Start date
D
Deleted member 4988
Guest
Just bought the Praxis 104bcd 34t chain for my Levo 19 .... this one is different from the standard that was fitted so what size chainrings bolts do I need.. length wise
Cheers
D
Deleted member 4988
Guest
The standard chainring you can bolt on too, the new praxis chainring doesn't have a threaded standoff
D
Deleted member 4988
Guest
Never realised that a simple question would have been so difficult to bloody answer !!!!! delete my sodding account !!
outerlimits
E*POWAH BOSS
1,241
1,574
It’s not rocket science ...... M8 thread 6.5mm long.
Hope your account is not deleted. You’ll be fun to play with around here ?‍♂️
20,498
Not rocket science
Or is it .... maybe the little men in their pod have to pedal like hell to run the auxiliary rocket fuel pumps .. I betting most of them upgrade their standard spaceX 32 tooth for a praxis 36, anything to reduce all that space suit chaffing ..
Wonder if any of them have created any vertical strava launch segments ...
But for the OP ... the praxis is normally threaded so you can re-use your existing bolts. I guess you've got that sussed now though :)
