Motors · Shimano
Shimano · EP8 series (DU-EP800)
EP8 (DU-EP800)
Shimano's 2020 game-changer: the DU-EP800 (EP8) shed weight, slimmed the Q-factor to 177 mm and turned the wick up to 85 Nm, dragging Shimano back into the fight with Bosch after the underpowered E8000 era. Not to be confused with the later EP801, which shares this hardware but adds firmware that lifts peak power.
EP8 (DU-EP800) eMTB motor
Shimano's DU-EP800 (EP8): lighter, narrower (177 mm Q-factor) and torquier than the E8000 it replaced.
0250500406080100120666 Wcadence (rpm) →power (W)
Strong, eager pull that peaks in the 70-75 rpm band at around 666 W (Velomotion, 250 W input) then fades as cadence climbs past 90 rpm.
The verdict
Shimano EP8 (DU-EP800) was the motor that made Shimano relevant again on eMTBs. Compared with the old E8000 it dropped to a claimed 2.6 kg, slimmed the Q-factor to 177 mm and jumped to 85 Nm of peak torque on a 250 W nominal rating. On the dyno it punched well above that nominal figure: Velomotion measured an average of 666 W at the wheel from 250 W of rider input at 70-75 rpm, and over 500 W from just 100 W of input.
A note on naming: this page covers the original EP8 (DU-EP800), not the later EP801. The two share core hardware and the same 85 Nm torque ceiling, but the EP801 lifts claimed peak from 500 W to 600 W through firmware and improves sealing and thermal management. Independent dyno data from ebike-lab is taken on an EP801 (firmware V4.4.1), so the measured figures quoted here for the EP8 come from Velomotion's EP8 test.
Character is the headline. The EP8 is sporty and eager, snapping to full assist from barely 100 W of rider input, which makes it feel lively and natural for a strong rider but a touch grabby for anyone wanting metered, tractor-like climbing. Its weakness is cadence: support is strongest in the 70-75 rpm band and sags as you spin past 90 rpm. The well-documented coast-clutch rattle on rough descents remains its most-complained-about trait. Still, as a benchmark of 2020-2023, it earned every bit of its reputation.
“Barely 100 watts of rider input unlocks over 500 at the wheel, and 250 W in returns a measured 666 W average — eager, sporty, and just a little grabby.”
Sustained power & heat
How long the headline number actually lasts under sustained climbing load.
Velomotion endurance climb (Boost, full pedal input)
Holds 100% for 40 min
~978 vertical metres, support did not drop; cold/wet conditions, so not a worst-case heat test.
Character
Rider input
Shimano publishes up to 400% maximum assist. Snaps to full support from just over 100 W of rider input, which makes it feel lively but can feel grabby on technical climbs.
On the trail
Sporty, dynamic and very lively off the bottom, peaking around 70-75 rpm and rewarding a strong, lower-cadence rider; less suited to those who like to spin fast or want smooth, metered power.
Noise
High-pitched whine on climbs like its rivals, but the notorious internal coast-clutch (freewheel) rattle on rough descents is its biggest acoustic gripe — noted in Velomotion's test and a recurring complaint in owner threads on EMTB Forums.
Efficiency
A frugal unit for its era — on flat ground at 100 W input it edged out the Bosch Performance CX for class-leading efficiency in Velomotion's testing, while being a touch more energy-hungry than rivals on a 10% gradient.
The case for and against
Strengths
  • 85 Nm peak torque; Velomotion measured a 666 W average at 250 W input
  • Light at a claimed 2.6 kg, with a slim 177 mm Q-factor
  • Lively, sporty, eager delivery
  • Class-leading flat-ground efficiency for its era
  • Highly tunable assist via E-TUBE app (up to 400%)
Compromises
  • Support is cadence-sensitive, strongest at 70-75 rpm and fading past 90 rpm
  • Notorious coast-clutch rattle on rough descents
  • Can feel grabby for riders wanting metered power
  • Superseded by the EP801, which adds peak power and better sealing
How it stacks up
Against the Bosch Performance CX of its day the EP8 matched torque on paper (85 Nm vs 85 Nm) and beat it for flat-ground efficiency, but felt punchier and less refined. Its later sibling, the EP801, raises claimed peak from 500 W to 600 W and tidies the mid-cadence delivery via firmware on the same core hardware. Newer units — Bosch's CX Gen 5, Specialized's 3.1 and DJI's Avinox — have since moved the torque and peak-power goalposts well clear.
OWNER INTELLIGENCE
Most owners report no problems · 7,087 posts from 848 members analysed.
77Clutch rattle / clack when coasting over rough ground · typical onset: From new.
30Random cutouts / system shutdown mid-ride (no error logged) · typical onset: ~1,000 miles is the repeated figure; some cases from 500 miles or after a motor service.
27Water / wet-climate sensitivity (connector corrosion and internal moisture) · typical onset: Seasonal - failures cluster after winter or wet trips rather than at a mileage.
37,500 km on one EP8 (Orbea Rise) - owner repaired the roller clutch himself at 24,300 km with donor parts and kept going
Read the full owner report →
