Bianchi
T-Tronik FX-Type Pro 2025
Current✎Trail/Enduro full-suspension eMTBAgeing · 4.2/10iFreshness 4.2/10
Motor
Shimano EP8 (DU-EP800) · 85Nm · 500W
Battery
Integrated 630Wh
Travel F/R
150/150mm
Wheels
29F / 29R✎
Frame
Full carbon✎
Weight
Price
£4,350✎
From £4,350
Trims · 1
XT Deore 12sp £4,350 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm |
| Battery | Integrated 630Wh · 630 Wh |
| Travel F/R | 150/150 mm |
| Frame | Carbon |
| Fork | RockShox Yari RC 29", 150mm, Maxle Stealth 15x110mm Boost, 42mm offset |
| Shock | Fox Float DPS Performance, LV, EVOL, 3-position lever |
| Headset | FSA NO.77R 1.5" |
| Stem | Velomann +/-0°, 1-1/8 x diam.35mm, 50mm |
| Handlebar | Velomann, width 780mm, diameter 35mm, rise 20mm, backsweep 9° |
| Grips | T-One Rock T-GP34 |
| Saddle | Fizik Alpaca Terra, S alloy rail, 249x145 mm |
| Seatpost | JD dropper, diam.31.6mm, internal remote cable routing, 100-150mm travel (size dependent) |
| Brakes | Shimano BL-M6100 / BR-M6120, 4-piston hydraulic disc (203mm front rotor) |
| Rear derailleur | Shimano Deore XT RD-M8100, 12-speed |
| Crank | Shimano FC-EM600, 165 mm with Shimano Chainring SM-CRE80-12-B, 34T |
| Shifters | Shimano Deore SL-M6100, 12 speeds |
| Chain | Shimano CN-M6100 |
| Drivetrain | Shimano Deore XT RD-M8100, 12-speed; Shimano FC-EM600, 165 mm with Shimano Chainring SM-CRE80-12-B, 34T; Shimano Deore SL-M6100, 12 speeds; Shimano CN-M6100 |
| Wheels | Shimano FH-MT510-B rear hub, Center Lock, 32h, 12x148 TA; Formula CL-811 front hub, Center Lock, 32h, 15x110mm TA |
| Tyres | Kenda Hellkat 29x2.6, 60tpi |
| Price | £4,350 |
Spot a mistake?
