Bike Finder · Rotwild
Rotwild R.E375
Rotwild
R.E375 2025
CurrentEnduro eMTBAgeing · 4.1/10iFreshness 4.1/10
Motor
Shimano EP8 (DU-EP800) · 85Nm · 500W
Battery
Rotwild IPU375 Carbon · 360Wh
Travel F/R
170/160mm
Wheels
29F / 29R
Frame
Full carbon
Weight
19.6 kg
View the Rotwild R.E375 on Rotwild’s site
Rotwild R.E375 2025
EMTB Forums verdict
The Rotwild R.E375 is a lightweight carbon enduro eMTB built around a deliberately small 360 Wh battery and the Shimano EP8 motor. Rotwild trades outright range for weight, with claimed figures of 19.6 kg for the Ultra and 20.4 kg for the Core, low for a 170 mm-travel ebike. The IPU375 carbon pack is removable via a QR-Button, and two riding profiles let you bias the bike towards maximum range or full support.
Geometry is aggressively enduro: a 63.5 degree head angle, 77 degree seat angle, long reach (460/482/510 mm across M/L/XL) and a consistent 445 mm chainstay. With 170 mm up front and 160 mm out back on 29in wheels, this is a bike built for steep, fast descending rather than all-day mileage.
The two builds share the same frame, motor, battery, seatpost and finishing kit, so the step up to the Ultra (8,990 EUR vs 6,990 EUR) buys FOX Factory Kashima suspension with Grip2 damping, Shimano XT brakes in place of Magura MT5, a full e*thirteen Race Carbon cockpit and crank, and Crankbrothers Synthesis Enduro I9 carbon wheels. The Core is the value pick and keeps the same EP8 drive and travel; the Ultra is the weight-and-spec halo.
💬 Forum discussion
Rotwild R.E 375
9 replies · 4.7k views · last reply 57 months ago
Join the discussion →
“Size L, vinyl wrapped, longer-than-stock 170mm seatpost and lightweight platform pedals = my not highly accurate scales say 19.8-20.1kg depending on how they're feeling. FWIW with the motor turned off the bike pedals better than my 2015…”
— Yoniboi · ♥ 3 · most-liked post
Bike geometry diagram
MLXL
Reach460 mm482 mm510 mm
Stack625 mm636 mm641 mm
Seattube440 mm470 mm506 mm
Chainstay445 mm445 mm445 mm
Headtube Angle63.5°63.5°63.5°
Seattube Angle (eff)77°77°77°
Wheelbase1253 mm1284 mm1311 mm
Headtube110 mm125 mm130 mm
BB Height350 mm350 mm350 mm
Standover730 mm730 mm730 mm
Front Centre808 mm*839 mm*866 mm*
Trims · 2
Core
Ultra
MotorShimano EP8 (DU-EP800) · 85 Nm · all trims
BatteryRotwild IPU375 Carbon · 360 Wh · all trims
Travel F/R170/160 mm · all trims
FrameHigh Modulus Carbon · all trims
ForkFOX 36 Float Performance, 170 mm / Grip / 3-PosFOX 36 Float Factory Kashima, 170 mm / Grip2 / HSC/LSC / HSR/LSR
ShockFOX Float X Performance, 230 x 60 mm / 2-PosFOX Float X Factory Kashima, 230 x 60 mm / 2-Pos Adjust
HeadsetAcros RW375 1.5 · all trims
Steme*thirteen Plus 35, 50 mm Length / AL7050 · all trims
Handlebare*thirteen Plus, 35 mm / 20 mm Rise / 780 mm Width / AL7050e*thirteen Race Carbon, 35 mm / 20 mm Rise / 780 mm Width / Carbon
GripsErgon GD10 Slim Factory Frozen · all trims
SaddleErgon SM Enduro Comp · all trims
Seatpost8PINS H01, 34.9 mm / Offset / up to 200 mm (XL) · all trims
BrakesFront: Magura MT5 HC-W; Rear: Magura MT5 HC-W ShiftmixShimano XT 8120 Fin Pad (front and rear)
Rear derailleurShimano XT 8100, 12-Speed / SGS / Hyperglide+ · all trims
Cranke*thirteen Plus, 160 mm (M) / 165 mm (L, XL), 34T direct mount chainring, e*thirteen TRS chain guidee*thirteen Race Carbon, 165 mm (M, L, XL), 34T direct mount chainring, e*thirteen TRS chain guide
ShiftersShimano XT 8100, I-Spec EV · all trims
CassetteShimano CS 6100, 10-51 T. / 12-SpeedShimano CS 7100, 10-51 T. / 12-Speed
ChainShimano HG 7100, 12-Speed · all trims
DrivetrainShimano XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Plus, 160 mm (M) / 165 mm (L, XL), 34T direct mount chainring, e*thirteen TRS chain guide; Shimano XT 8100, I-Spec EV; Shimano CS 6100, 10-51 T. / 12-Speed; Shimano HG 7100, 12-SpeedShimano XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Race Carbon, 165 mm (M, L, XL), 34T direct mount chainring, e*thirteen TRS chain guide; Shimano XT 8100, I-Spec EV; Shimano CS 7100, 10-51 T. / 12-Speed; Shimano HG 7100, 12-Speed
WheelsCrankbrothers Synthesis Enduro (front 31.5 mm / 110-15 mm 6-Bolt; rear 29.5 mm / 148-12 mm 6-Bolt)Crankbrothers Synthesis Enduro I9 Carbon, 29" / 31.5 mm front, 29.5 mm rear / Centerlock
TyresFront: Schwalbe Magic Mary Evo Super Ground / Soft / TLE / 29x2.4; Rear: Schwalbe Hans Dampf Evo Super Trail / Soft / TLE / 29x2.35 · all trims
Weight20.4 kg19.6 kg
Rides similarly
Spot a mistake?
