Steeper 68° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Bigfoot VLT 2025
The Bigfoot VLT is Norco's fat-bike take on a pedal-assist trail machine, built around a butted X6 aluminium hardtail frame, a 100mm Manitou Mastodon fork and 27.5 x 4.5in studdable rubber for snow and sand. Power comes from Shimano's EP8 drive unit fed by a removable in-tube pack offered in 540Wh, 720Wh or 900Wh capacities, so range and weight can be matched to the ride. Note the battery is sold separately from the frame.
Three builds make up the current line. The S2 is the value option, pairing a Mastodon Comp fork, Tektro HD-M275 brakes on 180mm rotors and a TranzX dropper with a Deore 12-speed drivetrain. The A1 steps up to the Mastodon Pro fork, SRAM DB8 brakes on a 200mm front rotor, WTB tubeless-ready wheels and an SDG Tellis dropper. The numbered "1" build sits at the top with the Mastodon Pro EXT fork, a Shimano XT rear mech, SLX shifter and a 203mm front rotor.
Geometry is consistent across the range with a 68 degree head angle, 460mm rear centre and reach growing from 410-420mm on the small to 500-510mm on the XL. The A1 and "1" share a slightly steeper effective seat angle and a higher bottom bracket than the S2, which carries a lower 329mm bottom bracket height and a marginally slacker seat tube. For a fat bike the figures are notably trail-oriented rather than upright touring, matching Norco's progressive-handling positioning.
Rear-long with a planted front in L (FC:RC 1.67) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Shimano EP8 (DU-EP800) and a steep 75.7° seat angle keep the weight planted over the front — a proper winch. 500W of peak power and 85Nm of torque — a strong full-power motor.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 96 bikes in the database)
| S | M | L | XL | |
| Reach | 420 mm | 450 mm | 480 mm | 510 mm |
| Stack | 631 mm | 640 mm | 649 mm | 649 mm |
| Seattube | 385 mm | 390 mm | 410 mm | 460 mm |
| Chainstay | 460 mm | 460 mm | 460 mm | 460 mm |
| Headtube Angle | 68° | 68° | 68° | 68° |
| Seattube Angle (eff) | 75.9° | 76.2° | 76.5° | 76.8° |
| Wheelbase | 1156 mm | 1186 mm | 1220 mm | 1254 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 130 mm |
| BB Height | 321 mm | 321 mm | 321 mm | 321 mm |
| Standover | 677 mm | 678 mm | 688 mm | 726 mm |
| Front Centre | 696 mm* | 726 mm* | 760 mm* | 794 mm* |
| FC:RC | 1.51 | 1.58 | 1.65 | 1.73 |
Trims · 3
1 £4,190 | A1 | S2 | |
| Motor | Shimano EP8 (DU-EP800) · 85 Nm · all trims | ||
| Battery | Norco VLT 900Wh · 900 Wh · all trims | ||
| Travel F/R | 100/? mm · all trims | ||
| Frame | Aluminium · all trims | ||
| Fork | Manitou Mastodon Pro EXT, 100mm Travel | Manitou Mastodon Pro, 100mm, 51mm Offset, 15x150mm | Manitou Mastodon Comp, 100mm Travel |
| Headset | FSA No.55R Tapered | Tapered 1-1/8"-1.5" (ZS44/28.6 | ZS56/40) | FSA No.55R, Sealed Bearing, Tapered |
| Stem | 6061 Alloy, 50mm Length, 35mm Clamp | Norco Alloy, 40mm Length, 35mm Clamp | 6061 Alloy, 50mm Length, 35mm Clamp |
| Handlebar | Butted 6061 Alloy, 780mm, 20mm Rise | Norco 6061 DB Alloy, 800mm, 25mm Rise | Butted 6061 Alloy 760mm, 15mm Rise |
| Grips | WTB Waffle Lock-On | Propaml Pro, 130mm | WTB Waffle, Lock-On |
| Saddle | SDG Bel-Air V3 · all trims | ||
| Seatpost | TranzX YSI22PLQ Dropper, 34.9mm, 150mm (S) / 170mm (M, L) / 200mm (XL) | SDG Tellis, 31.6mm, 150mm (S) / 170mm (M/L) / 200mm (XL) | TranzX YSP18 Dropper, 31.6mm, 130mm (S, M) / 150mm (L, XL) |
| Brakes | SRAM DB8, Sintered Pads | SRAM DB8, Sintered Pads | Tektro HD-M275 Hydraulic, Resin Pads |
| Rear derailleur | Shimano XT RD-M8100 | Shimano Deore RD-M6100, SGS, 12sp | Shimano Deore RD-M6100 |
| Crank | Samox Alloy, 32T, 165mm | Samox Alloy, 32T, CL72, 165mm | Samox Alloy, 32T, 165mm |
| Shifters | Shimano SLX SL-M7100-IR | Shimano Deore SL-M6100-R, 12sp | Shimano Deore SL-M6100-R |
| Cassette | Shimano SLX, 10/51, 12 Speed | Shimano Deore CS-M6100-12, 10-51T, 12sp | Shimano Deore CS-M6100-12, 10/51T, 12 Speed |
| Chain | Shimano Deore | Shimano Deore CN-M6100-12, 12sp | Shimano Deore CN-M6100 |
| Drivetrain | Shimano XT RD-M8100; Samox Alloy, 32T, 165mm; Shimano SLX SL-M7100-IR; Shimano SLX, 10/51, 12 Speed; Shimano Deore | Shimano Deore RD-M6100, SGS, 12sp; Samox Alloy, 32T, CL72, 165mm; Shimano Deore SL-M6100-R, 12sp; Shimano Deore CS-M6100-12, 10-51T, 12sp; Shimano Deore CN-M6100-12, 12sp | Shimano Deore RD-M6100; Samox Alloy, 32T, 165mm; Shimano Deore SL-M6100-R; Shimano Deore CS-M6100-12, 10/51T, 12 Speed; Shimano Deore CN-M6100 |
| Wheels | Sun Ringle Mulefut SL V2, 27.5", 32H | WTB ST i76, 27.5", 32h | Sun Ringle Mulefut SL V2, 27.5", 32H |
| Tyres | Vee Snow Avalanche, TLR, 4.5", 120 TPI, Studdable (front & rear) | WTB Bailiff, 27.5"x4.5", TCS Light/High Grip 120tpi (front & rear) | Vee Snow Avalanche TLR 4.5", 120 TPI, Studdable (front & rear) |
| Price | £4,190 | — | — |
Rides similarly
Spot a mistake?
