Bike Finder · Rotwild
Rotwild R.E375
Rotwild
R.E375 2026
CurrentEnduro eMTBMature · 5.8/10iFreshness 5.8/10
Motor
Shimano EP8 (DU-EP800) · 85Nm · 500W
Battery
Rotwild IPU375 Carbon · 360Wh
Travel F/R
170/160mm
Wheels
29F / 29R
Frame
Full carbon
Weight
19.6 kg
View the Rotwild R.E375 on Rotwild’s site
Rotwild R.E375 2026
EMTB Forums verdict
The Rotwild R.E375 is a carbon enduro eMTB built around a compact 360 Wh battery and the Shimano EP8 motor (85 Nm, max 500 W), trading outright range for a low system weight. At 20.4 kg for the Core and 19.6 kg for the Ultra in size M, it is notably light for a 170/160 mm enduro machine, and Rotwild positions it as a quick lap bike with two riding profiles spanning maximum range and full support.
The geometry is aggressive: a 63.5 degree head angle, 77 degree seat angle and 445 mm chainstays across all sizes, with reach growing from 460 mm (M) to 510 mm (XL). Wheelbases run 1253 to 1311 mm, so it reads as a stable descender rather than a tight-turning trail bike.
The two builds share frame, motor, battery, geometry, seatpost and finishing kit, so the 2,000 EUR step from Core to Ultra buys upgrades rather than a different bike: FOX Factory Kashima suspension with Grip2 damping in place of Performance Grip, Shimano XT brakes over Magura MT5, a carbon e*thirteen cockpit and crank, and carbon Crankbrothers Synthesis wheels. Riders set on a lighter, more tunable build will find the Ultra the more complete package, while the Core covers the same chassis and motor for less.
💬 Forum discussion
Rotwild R.E 375
9 replies · 4.7k views · last reply 57 months ago
Join the discussion →
“Size L, vinyl wrapped, longer-than-stock 170mm seatpost and lightweight platform pedals = my not highly accurate scales say 19.8-20.1kg depending on how they're feeling. FWIW with the motor turned off the bike pedals better than my 2015…”
— Yoniboi · ♥ 3 · most-liked post
Bike geometry diagram
MLXL
Reach460 mm482 mm510 mm
Stack625 mm636 mm641 mm
Seattube440 mm470 mm506 mm
Chainstay445 mm445 mm445 mm
Headtube Angle63.5°63.5°63.5°
Seattube Angle (eff)77°77°77°
Wheelbase1253 mm1284 mm1311 mm
Headtube110 mm125 mm130 mm
BB Height350 mm350 mm350 mm
Standover730 mm730 mm730 mm
Front Centre808 mm*839 mm*866 mm*
Trims · 2
Core
Ultra
MotorShimano EP8 (DU-EP800) · 85 Nm · all trims
BatteryRotwild IPU375 Carbon · 360 Wh · all trims
Travel F/R170/160 mm · all trims
FrameHigh Modulus Carbon, Carbon Linkage · all trims
ForkFOX 36 Float Performance, 170 mm / Grip / 3-PosFOX 36 Float Factory Kashima, 170 mm / Grip2 / HSC/LSC / HSR/LSR
ShockFOX Float X Performance, 230 x 60 mm / 2-PosFOX Float X Factory Kashima, 230 x 60 / 2-POS Adjust
HeadsetACROS RW375 1.5 · all trims
Steme*thirteen Plus 35, 50 mm Length / AL7050 · all trims
Handlebare*thirteen Plus, 35 mm / 20 mm Rise / 780 mm Width / AL7050e*thirteen Race Carbon, 35 mm / 20 mm Rise / 780 mm Width / Carbon
GripsERGON GD10 Slim Factory Frozen · all trims
SaddleERGON SM Enduro Comp · all trims
Seatpost8PINS H01, 34.9 mm / Offset / up to 200 mm (XL) · all trims
BrakesFront: MAGURA MT5 HC-W; Rear: MAGURA MT5 HC-W ShiftmixFront: SHIMANO XT 8120 Fin Pad; Rear: SHIMANO XT 8120 Fin Pad
Rear derailleurSHIMANO XT 8100, 12-Speed / SGS / Hyperglide+ · all trims
Cranke*thirteen Plus, 160 mm (M) / 165 mm (L, XL); e*thirteen Direct Mount Chainring 34 T.; e*thirteen TRS chain guidee*thirteen Race Carbon, 165 mm (M, L, XL); e*thirteen Direct Mount Chainring 34 T.; e*thirteen TRS chain guide
ShiftersSHIMANO XT 8100, I-Spec EV · all trims
CassetteSHIMANO CS 6100, 10-51 T. / 12-SpeedSHIMANO CS 7100, 10-51 T. / 12-Speed
ChainSHIMANO HG 7100, 12-Speed · all trims
DrivetrainSHIMANO XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Plus, 160 mm (M) / 165 mm (L, XL); e*thirteen Direct Mount Chainring 34 T.; e*thirteen TRS chain guide; SHIMANO XT 8100, I-Spec EV; SHIMANO CS 6100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-SpeedSHIMANO XT 8100, 12-Speed / SGS / Hyperglide+; e*thirteen Race Carbon, 165 mm (M, L, XL); e*thirteen Direct Mount Chainring 34 T.; e*thirteen TRS chain guide; SHIMANO XT 8100, I-Spec EV; SHIMANO CS 7100, 10-51 T. / 12-Speed; SHIMANO HG 7100, 12-Speed
WheelsCRANKBROTHERS Synthesis Enduro; Front 31.5 mm Width / 110-15 mm / 6-Bolt; Rear 29.5 mm Width / 148-12 mm / 6-BoltCRANKBROTHERS Synthesis Enduro I9 Carbon, 29"; Front 31.5 mm / 110-15 mm / Centerlock; Rear 29.5 mm Width / 148-12 mm / Centerlock
TyresFront: SCHWALBE Magic Mary Evo Super Ground / Soft / TLE / 29x2.4; Rear: SCHWALBE Hans Dampf Evo Super Trail / Soft / TLE / 29x2.35 · all trims
Weight20.4 kg19.6 kg
Rides similarly
Spot a mistake?
