Levo Gen 2 Seat post cable housing question
tnull5
22
Valencia, California
Does the housing on the Levo go all the way through? In other words, is it one piece? I bought a One Up seat post and Wolf Tooth lever and the barrel end and cut ends are reverse from what is stock. So I need to pull the cable all the way out and reverse it. Since it is new, I want to reuse the cable and housing. Seems like it should be, but a friend said that on other bikes (non E ) it is two pieces and a bitch to rethread. Thanks for the input.
ScottWest
123
76
Oregon
The housing is one piece. Most likely you will need a new cable, the original one might be to short for the new lever.
KennyB
824
563
Taunton
Definitely one piece. Look at the Retailers Technical Workbook for the routing of the housing. There are links to this in one of the forums. I can see no need to change the housing, but you will have to change the inner cable, cut the frayed end neatly so you don't damage the housing. A brand new one, with an uncut soldered end, should go through fine.
525K
