Levo Gen 3 Oil leaking from Levo Motor Casing
SteveRS
107
75
British Columbia Canada
I’ve had oil leaking from my gen3 Levo expert several times. see photo. It appears around the rubber cover in front of rear wheel as well as the plastic motor cover. When I take the rubber cover off it’s wet with oil below the cover. I’ve taken out my dropper post wondering if it’s the post, is there oil in the dropper cartridge? The dropper is a x fusion manic. If it’s not the dropper then it must be motor oil. It’s not coming from the rear shock either. It’s a thin viscosity oil as far as I can tell by feel and smells like automotive oil. Any other ideas? If the dropper cartridge doesn’t have oil in them, then I’ll take the bike in the the LBS to have it checked out.
