Help! Chewed allen bolt
DC29
7
Glasgow
Hi guys, just wondering if anyone could help me. I was having difficulty getting my allen bolt to loosen on my bike which ended up getting chewed. Now while trying to fix it a drill bit had snapped inside it. Any ideas what to do? Thanks
Planemo
591
692
Essex UK
Carefully cut a slot in it with a dremel and use a quality large flat-bladed screwdriver. I have some drivers with an 8mm hex at the top of the shaft to provide some additional leverage with a spanner. If you don't have the hex, try the old kerbside autos method of clamping a set of mole grips onto the shaft super tight.
DC29
7
Glasgow
Thanks I’ll give this a go
20,507
The other thing to do is hammer in a Torx drive.
I keep meaning to change the axle, but it's still working fine in it's "bodged" state ..
towzer
95
48
Oxfordshire
This Might not work (*old motorbike seized screw etc trick), and take care as not much metal on a bicycle. but fyi, Can you punch/chisel (with a sharp punch or small sharp chisel(even flat screwdriver), hitting it in (gently) with a hammer, , create a indent in the outside edge of the bolt head (by punching/hammering straight down) and then once you have created a small indent then use the indent to punch/hammer the bolt in the undo direction.
8,694
Be certain to know which way to loosen the Allen bolt and which way the black thing with the writing on it.
You can never be too careful with bikes. They are the only thing I have come across where left-hand threads crop up, and not just on the pedals!
Stihldog
Handheld Power Tool
2,957
4,180
Coquitlam, BC
I’ve only used these twice but they saved the crank. 9/16” left and right thread taps.
When I’m not sure of the type of thread used (left or right) I sometimes use a torque wrench with the correct setting which can tighten or loosen a bolt. I stay within the torque specs and try to turn the bolt both ways. There’s less chance of a damage when the right sized socket or Allen key is used. IMG_6753.jpeg
p3eps
1,883
2,250
I bought these for that exact reason. They’re specific Allen bolt removers for when the heads get slightly rounded.
I was looking at thePark Tools THH-1 Allen key set the other day, and they have these fitted to one end.
I think you need to try and get the broken drill bit out, and then use something like this to remove the bolt.
B1rdie
836
1,034
Brazil
It seems to be a counter clockwise threaded bolt, so you can use a regular drill to make a hole and a superb screw to drive it out. 20 nm is a very light torque, so, if turned on the right direction it should not be too hard to remove it.
If it is a regular clockwise tightening bolt, you can find counter clockwise drills and superb bolts to do it.
RustyMTB
2,568
6,286
Probably Stihldog or P3eps posts are the ideal tools. Otherwise, this impact screwdriver is the single best tool I've ever owned for these situations. If you can get a bit to fit, it uses shock force to turn a fixing & it's very effective.
theremotejuggernaut
302
234
I don't think extractors are the answer in this case. Op says there's a snapped drill bit in the middle on the hex.
@DC29 how much depth do you have in the hex before you hit the drill bit?
I'd imagine that the axle will be hollow so hammering a tor bit into the other (open) end and unwinding it that way might be the way to go.
Can we have a pic of the dropout on the other side so we can see the other end of the axle?
525K
