Cube one77 2025
Some more experience to share, that may be of interest to those that were between sizes and went up a size. I went up from a L to XL, as the L was slightly short on reach and too short on seat stay length (I hit min insertion depth for the dropper post with the 165 cranks when I tested it). So I went for the XL, but always felt it was perhaps 10mm too long in the reach. So, I saw these ethirteen plus 35 stems in the 40mm length, on offer on the ethirteen UK website at £36 down from £90 rrp. The stem that came with the bike is 50mm length and also around 15-20mm rise (I always felt that rise was excessive and not needed). Anyway, I’ve fitted the new stem and, apart from the colours being a great match to the carbon/gold bike scheme, it‘s made the bike ride exactly how I’d hoped. I now feel fully balanced on it and it has‘t moved weight off the front wheel, as the rise drop has more than counteracted the loss of 10mm in reach length; I actually feel I have slightly more weight over the front now.
In summary, if you were on the size fence and went up, I’d highly recommend giving this mod a go (especially whilst ethirteen are nearly giving these stems away).
View attachment 165660View attachment 165661
Now for the sucky news, I’m in for a right knee ACL reconstruction op this week, so this was my last ride until next spring ☹️. An old injury that really needs fixing before my knee completely destroys itself, so it is what it is.
Don't worry you'll be in and out in a weekend .
Where do you ride locally? You have a sit on mine if you're close by.
Merthyr Vale and edwardsville are my locals. I am quite often in sidings, willi
Merthyr Vale and Edwardsville is my local loop, I'm often in sidings, wyllie, Risca ect. Where are you riding.
I'm in Taffs Well area so Castle Coch / Caerphilly / Rudry / Machen. Not far at all.
If you want to see the bike before buying youy can take a look at mine
Been to smolo
Thanks for the offer bud we already bought two of them last week (impulse buy). Should be here next week the bike shop is going to grease and tourqe everything.
Straight to dons then to get them wrapped hopefully get out the week after.
Has anyone installed Kiox 400C yet? As I expected, it requires a special adapter. I suspect it's due to the shape of top tube, which isn't flattened, but oval. Without adapter, display would either stick out, or be hidden very far. But of course, there could be other reasons too ;)
I take it this makes the bar mounted display redundant? Does that need unplugging and disconnecting from wherever it’s plugged into?
I've read somewhere that yes it makes the Kiox 400 redundant so on that basis I'm sticking with the 400 and not getting the 400c. The bar mounted one works well enough for me.
New pedals to further support offsetting the low BB.
I'm off to the French Alps in a couple of weeks so I'm very excited about taking it on some proper long Alpine trails.
I did try and fit a Fidloc 750ml compact bottle but it didn't fit on my medium frame, pretty gutted about that.
I think I've asked this before but my headset "cover" doesn't fit flush or "level". I've just switched to the slacker setting ahead of my alps trip and couldn't get it flush when I clamped it back together.
Anyone else's look like this?
View attachment 165958View attachment 165959
Looking good, do you have some favorite areas to ride in the Alps.
Staying in Bourge Saint Maurice then exploring from there. I’ve done most resorts etc over the years but not been for 12 years!
I like off piste stuff but just happy to have a week dedicated to riding my bike. 😁
Over 2000 miles in the last 4 months and all is good, a lot of chat about low BB, it really isn’t that bad but have 160mm Cube ones fitted.
Even on trails like this.
How you guys feel on the slx vs tm version?
Most def how you feel the xt brakes compare to the mt 7
I have been a big fan of the XT 8120 brakes they are light years above the sram code brakes I use on another bike. I chose the SLX because of my old school preference for cable shifting and so XT is my choice for transmission
Just purchased a DHX coil for my cube. It’s going to be interesting to compare my air shock to this. It’s my first ever coil so I’ve got some learning to do.
I look forward to the results! Keep us updated.
Think all I did was loosen it up then keep twisting it side to side and it clipped in. I think I’ve helped my self by removing the light cable from the headset as it’s that plastic bracket what stops it being flush I think. I could be wrong tho.
Thanks for that. I’ll try without the light cable, I run a different stem with normal, round, spacers, so maybe that effects the fit a bit.
Speaking of lights, has anyone managed to connect an acid light from cube with the plug and play connector in the headset that looks like a C? Nothing happens when I plug mine in!
    670K
