It has 2 led's - a green one that comes on when you switch the bike on, then another one next to it, which is unlit when power assistance is off, blue when Eco, Green when Trail, and Red when Boost. The little button is for activating the bluetooth connection, you just hold it down for a couple of seconds and the power LED starts flashing to indicate its looking for a connection. The bike is switched off in the pictures. There is also a red battery symbol that comes on when you get down to one bar.
I keep my phone in my pocket, I can see the battery life left when on the bike by looking at the battery LED's, but if I want to check range etc I just pull the phone out. The phone app is designed to replicate a display, so you could mount the phone to the bars, you can customise the app to display all the info at once, or just what you want, so it soul just display cadence and speed for example.
I suspect the Junction A could connect to a Garmin and you could display the info via the Shimano Steps function that I think the latest gARMINS HAVE.
New Garmin Edge with Shimano Steps integration - EMTB Forums
The story behind the shock is that the bike went into a LBS for full suspension service, and to alter the fork travel (I had a crash and needed time off the bike, so took the opportunity to do this as was overdue).
Long story short they sent the suspension off to Sram Tech Centre to be serviced, which they where told would take 4 days, but ended up being a nightmare and taking 4 weeks (I only got the bike back on Friday, just in time for the Forum ride).
I had intended to fit the coil myself, but given how long Sram where taking, I asked the shop too, and they had the issue - I went in to have a look, and took the attached picture, but it wasn't an ideal situation to try as at the time I went in to double check as the bike was stripped down and not on a work stand, but you could see where the coil hits the frame.
However I want to check this all through again, i just want to ride the bike now, but will give it a go myself in a couple of weeks. I reckon I may be able to get it to work, with a very tight clearance, I think it would fit when sagged, my concern is that it would still rub/hit with no load on it.
I also have a Meg Neg can on order to try out.
