I made a DIY 12s3p battery. I used LG M58T 21700 cells. The capacity should be around 720 Wh. The original battery was 410 Wh.
I tested it for a few charge cycles. Now I have a problem. The motor controller thinks the battery is still 410 Wh. Also, I cannot get below 50% of the battery capacity (on the BMS).
Here is the comparison (Display % / BMS app %):
  • 90 / 90
  • 70 / 70
  • 66 / 64
  • 54 / 57
  • 44 / 55
  • 20 / 55 (after 5 days of no use)
I looked into the Bafang app and the display settings. I cannot find any option to change the battery capacity. Has anyone seen this problem before?
  • 90 / 90
  • 70 / 70
  • 66 / 64
  • 54 / 57
  • 44 / 55
motor cant see baterry capacity if battery has no can conection ,please show us battery :)
  • 90 / 90
  • 70 / 70
  • 66 / 64
  • 54 / 57
  • 44 / 55
Install the appropriate version of FAKE TAXI for your battery and everything will be fine.
  • 90 / 90
  • 70 / 70
  • 66 / 64
  • 54 / 57
  • 44 / 55
pls show us your DIY battery
you need a bms or battery with canbus connection to read anything from the battery. without can only see a calculated (guess) battery percentage
which isnt very correct most of the times
    673K
