Very tidySome of you are killing my OCD with your cables, haha. Here is my setup. I wish I could eliminate the brake cables too! View attachment 183193
But ... Oddly wrong to see a LHD cockpit (to someone from UK/AUS/HK/?)
Looks nice but it won't work out too well after your first big 'get off' and those bars rip your cables out of the masters!Some of you are killing my OCD with your cables, haha. Here is my setup. I wish I could eliminate the brake cables too! View attachment 183193
I had the some problem with this as well. I assume you're referring to the sram axs power cord. Every time I tried to pull it through (rear to front) it got hung up in the chainstay. I was using the supplied cable guide, a park tool cable routing kit, lawn trimmer string and shifter cable. All those methods failed because the thinner guide/cable/string will follow a thinner route thru the chainstay so the fatter connector for the power cord will get hung up. I finally routed some shifter cable housing (4mm) from the front hole to the rear. I then taped the power cord connector to the cable housing and pulled it back thru to the front. The thicker cable housing will follow a path that the connector can fit thru.Having trouble with the thread search and ready to rip my hair out with this AXS cable routing. Can someone please point me to some help with this thing. Thank you in advance!
No issues with this. They are long enough to avoid this.until your
I was considering getting your Rulezman 15 mm stem but it costs about the same $336 + shipping + tariff (the last bike items I had shipped from Europe came with tariff bills from FedEx).I’d probably wait and see how the stem feels with your stock reach before you order the -5* headset. It might feel good as is. If it still feels too long out front, then get the -5 headset.![]()
5'10" with an RH2. Plan is to ride the thing a bunch and fine tuning prior to any aggressive geo changes.Are any of you shorter RH2 riders using the -5 mm reach adjust headset? (it was sold out when I ordered my Forge frame)
Are any of you shorter riders going to try the BeMoreBikes Gen 2 90 mm RR (Reversed Raised) stem on your RS 181.2?
I doubt I'd feel comfortable with the taller 150 mm version that @Rob Rides EMTB is using...
I ordered one, hopefully it will be worth its $400 cost.
You are killing my ocd with those qr codes and 4 wireless controllers!?!Some of you are killing my OCD with your cables, haha. Here is my setup. I wish I could eliminate the brake cables too! View attachment 183193
Still have the shipping covers on the fork tho?Some of you are killing my OCD with your cables, haha. Here is my setup. I wish I could eliminate the brake cables too! View attachment 183193
5'10" here on a RH2 as well. My current bike, TR Relay size M has a 452 reach, 634 stack, with 40mm stem and 35mm rise bars. This bike is one of the most fun, comfortable bike's I've ridden. I feel like I have a ton of power to move the bike around so my leverage points must be pretty dialed with the effective reach.5'10" with an RH2. Plan is to ride the thing a bunch and fine tuning prior to any aggressive geo changes.
I think I am liking the shorter reach so far personally. I found my old bike I slid the seat up all the way forward, I seem more centered with my seat and weight on the Crestline.
They're not intended for use while the fork is on the bike.What !?
Shipping covers ?
I thought they were rather snazzy dust covers. I'm leaving mine on.
Not all of us feel comfortable walking around with our nipples outStill have the shipping covers on the fork tho?
Thank you for the response! I eventually followed a similar technique and finally got it! Took lots of patience for sureI had the some problem with this as well. I assume you're referring to the sram axs power cord. Every time I tried to pull it through (rear to front) it got hung up in the chainstay. I was using the supplied cable guide, a park tool cable routing kit, lawn trimmer string and shifter cable. All those methods failed because the thinner guide/cable/string will follow a thinner route thru the chainstay so the fatter connector for the power cord will get hung up. I finally routed some shifter cable housing (4mm) from the front hole to the rear. I then taped the power cord connector to the cable housing and pulled it back thru to the front. The thicker cable housing will follow a path that the connector can fit thru.
Getting the shifter cable housing thru initially was not easy either but if you keep fishing, you will get it to a point where you can see the end of the cable thru the rear hole. When you get it that far, you can use a small pick (maybe a tooth pick or dental pick) to fit into the cable end and guide it thru to rear hole.
I have 22.5mm under mine. I just saw this video last night and went straight in the garage. Sure enough, it was bang on for me. I guess thats why I felt instantly comfortable on this bike. One of the reasons anyway.Back to the bike….
How many mm’s of stem spacers did you guys put under your stem?
Hey Nick, I'm the same height as you and am concerned about the the RH2 size being a little bigger than I'm accustomed to. Are you riding your's already? How do you like the size? Did you change the dropout or go -5 on the headset? Standover is fine? Thanks in advance!I’m 5’6 with 29 or 30 inseam. I tried to do the math the best I could and it seemed like a 180 fully slammed might be right on the edge of being too high for me. I wondered if I ran a super low profile seat like an sq lab 611 it might fit perfectly
Once below 10%ish the best assist you'll get is auto no matter what mode you set it in.So did my second ride today. 3 laps of the Luge in OC. I decided to put the hammer down to see what it could do. It’s just crazy good. I ended up with 5% battery left and it slowed considerably on the 3rd lap. Probably thermal overload. So I put it in auto once that happened. Still awesome ride. The bike was really really good. 49 achievements and 11 KOM’s!
My Strava ride
Damn you're ripping! nice times!So did my second ride today. 3 laps of the Luge in OC. I decided to put the hammer down to see what it could do. It’s just crazy good. I ended up with 5% battery left and it slowed considerably on the 3rd lap. Probably thermal overload. So I put it in auto once that happened. Still awesome ride. The bike was really really good. 49 achievements and 12 KOM’s!
My Strava ride
It’s always rideable, but best conditions are like 2 days after a rain. Otherwise even on the hot days, just get an early start and you’ll be good.Once below 10%ish the best assist you'll get is auto no matter what mode you set it in.
Luge has been on my to do list. When does it get unridable hot out there?
Thanks brother! I figured I might have a couple good ones, but I had no idea it would be 12! The bike just rips though!Damn you're ripping! nice times!
Dang I need to buy two two steps…I have 22.5mm under mine. I just saw this video last night and went straight in the garage. Sure enough, it was bang on for me. I guess thats why I felt instantly comfortable on this bike. One of the reasons anyway.
Clip from youtube:
Why are you trying to get to the sim slot?Be careful when trying to get the sim slot cover off the display. They use locktite and those screws are tiny. One of mine just won’t budge and I stripped the head. So pissed. Gonna take it to a mobile phone repair place and see if they can extract the screw.
