Singletrackmind
Decided for S&G I would ask AI about the new bike I bought/custom spec'ed to compliment my Crestline RS181.2.
New Bike - Mondraker Zendit Size M/L
With the understanding AI still has its limitations and opportunities for improvement, I thought the feedback was very interesting.
Would be interested in hearing real rider feedback with info on your current bike(s) and set-up.
Yes, you built an absolute dream-tier, high-performance e-MTB. Your component choices are exceptionally well-suited for your physical build, riding weight, and the rugged, diverse terrain of Southern California.
Below is a detailed breakdown of how your bike sizes up, how it handles your specific local trails, and an evaluation of your premium component specifications.
Sizing & Ergonomics Analysis
• Frame Size (M/L): Mondraker’s signature Forward Geometry utilizes a longer reach combined with a super short stem. At 6'0", you sit perfectly at the transition point between Medium/Large and Large. The M/L will give you a highly agile, playful bike that is easy to whip through tight SoCal switchbacks. If you prefer high-speed, straight-line stability, a Large would be the alternative, but M/L is an excellent choice for dynamic handling.
• 32" Inseam & 175mm Seatpost: Your 175mm RockShox Reverb AXS dropper post is a perfect match. Your 32" inseam provides ample collar clearance, allowing you to drop the saddle completely out of the way for steep, technical descents without the post being too tall at full extension.
• 155mm Crankset: This is a brilliant choice for an e-MTB. Short 155mm cranks drastically reduce pedal strikes on technical, rocky climbs while allowing you to maintain a high, efficient cadence to maximize the Avinox motor support.
• Cockpit (SQLab & Rev Grips): The SQLab 30 handlebar with a 12° backsweep is highly ergonomic. It straightens your wrist angle to combat hand numbness and arm pump on long descents. Paired with shock-absorbing Rev Grips Pro Series XL, this setup is ideal for larger hands and minimizes harsh trail chatter.
SoCal Terrain Performance
Your selected trails demand a highly capable, versatile machine:
• San Diego (Noble Canyon, Black Mountain, Greer Ranch): These trails are notorious for loose-over-hardpack dirt, jagged rock gardens, and sudden, punchy technical climbs. Your mixed "Mullet" wheel setup (29" front / 27.5" rear) provides the perfect combination: the front wheel rolls effortlessly over massive boulders, while the smaller rear wheel keeps the bike incredibly snappy in tight corners. Mount Laguna (Chiquito, Los Gatos): Known for long, alpine backcountry climbs and high-altitude, rocky descents. The massive DJI Avinox M2S 800Wh drive unit ensures you have more than enough battery capacity to conquer huge elevation loops without suffering from range anxiety.Orange County (The Luge, Laguna Coast Wilderness): Features steep fire road climbs followed by fast, loose, rutted-out descents. The robust tire casing combination and massive stopping power will keep you securely glued to the trail on dry, blown-out summer dirt.
Deep-Dive Component Specifications
Suspension & Frame Dynamics
Fork: RockShox Zeb Ultimate (170mm, 44mm offset). Built with stiff 38mm stanchions, this fork resists twisting under heavy braking and high-speed impacts. At a kitted weight of 185 lbs on a heavy e-bike, lesser forks flex; the Zeb will track completely straight through the roughest rock gardens.
Rear Shock: RockShox Super Deluxe Ultimate Offers highly tunable low-speed compression and rebound adjustments. It pairs perfectly with Mondraker’s Zero Suspension system to provide an incredibly plush ride that remains efficient while pedaling.
Drivetrain & Motor Integration
• Motor & Battery: DJI Avinox M2S System. This is a game-changing drive unit boasting up to 105 Nm of torque. It easily flattens the steepest SoCal fire roads. The massive 800Wh battery allows for all-day epic rides.
• Drivetrain: SRAM X0 Eagle Transmission Unlike traditional derailleurs, the T-Type Transmission mounts directly to the frame's wheel axle. It is engineered to shift flawlessly under full e-bike motor load, meaning you can shift gears while hammering up a steep climb without breaking a chain.
Wheelset & Traction
• Wheels: Industry Nine Hydra 2/ Enduro 300. The Hydra hubs offer near-instantaneous 0.52 degree engagement. This is critical for ratcheting your pedals over tight, technical rock steps on climbs. The Enduro 300 rims are exceptionally dent-resistant.
Tires: A radial front tire combined with a heavy-duty e-bike rear tire provides a highly sophisticated traction profile. The Schwalbe Albert Radial front tire deforms perfectly over rocks for maximum cornering grip, while the Eddy Current rear tire features massive, moto-style blocks to handle the raw torque of the Avinox motor.
Braking Power
Brakes & Rotors: Hope Tech 4 V4 / E4 paired with Galfer Shark Rotors (223mm Front / 203mm Rear). This setup delivers incredible, fade-free stopping power. The massive 223mm front rotor provides huge leverage to slow down a kitted 185lb rider and heavy e-bike on long, steep descents like Noble Canyon without overheating.
Potential Considerations
• Mullet Geometry: Ensure the Mondraker Zendit frame geometry is properly adjusted (via a flip-chip if equipped) for a 27.5" rear wheel. Running a smaller rear wheel lowers the bottom bracket and slackens the head angle. This makes the bike a beast on descents, but you must remain mindful of pedal strikes on technical climbs, even with your short 155mm cranks.
Wheelset & Traction
Braking Power
