This seems to get repeatedly and endlessly discussed in multiple parallel threads, so :
You need the SRAM AXS Cable (Higo Micro A ??). Most people seem to go for the 955mm option (also available in 780mm 028.003).
Manufacturer Item code : 11.3018.028.001
Or SRAM Model ID : EP-EAC-ECD-A1
Search for either of those and you should find a selection of vendors.
It's expensive for what it is. You can buy the cable in two parts and make one up, which is cheaper, but it's not easy finding the two ends : Haven't seen them on aliexpress for example.
Example links to the diy option in this post (though not 100% Sure the motor end connector is the correct on in the links) :
run max power while we can I have a fast bike now, and I beat it to death, 2700 miles for 2025 so far and 360,000 feet of climbing. Im buying this for more KOMs so it will get beat on for all its worth. With that said riding 5 days a week and averaging 100 miles, and not all 100 miles are me...
www.emtbforums.com
