kimochi
oh, not looking to go through all the hassle of building it from frame up, electrical and all. was hoping something similar to mondraker or crestline
alright, I think lowest tier it is then.For a brand new release, I can't imagine there's a chance you'd see a frame-only option come in any cheaper than buying the full bike and selling off what you don't need.
Maybe later in its life once the initial sales buzz has worn off, but anything available now is going to command a premium price because they can.
FWIW the price of the frame alone that I have seen is equivalent to the lowest tier of build, once you add in the motor and battery. Probably more, once it all shakes out.
As @Free54 says that might just be an SKU for dealers to order-in for warranty purposes, but that's the only option I have seen, both in a Trek store and on various Trek dealer websites.
According to my friendly, neighbourhood Trek dealer, the frame only options are there if someone is stupid enough to want one. They have their own ordering system for parts and accessories.alright, I think lowest tier it is then.![]()
My large framed EX 9.8 XT with carbon wheels, was 20.2 kg, as delivered, with the 580 battery excl. pedals. I have got it down to 19.6 kg (ready to ride incl. pedals), after swapping in a few lighter components. With an LX Eagle 90, low 20's kg might be achievable, but the factory spec reckons on 20.88kg excl. pedals as delivered, so it could be a challenge. I guess the coil and the fox 38 fork on the LX adds a bit to the weight compared to the EX.Seriously thinking on a LX eagle 90 / enduro build with coil to replace my acoustic m enduro bike ( Pivot Firebird) which doesn’t get too much love since the Full Bosch CX bike does a heck of a job but thinking at a 20ish kg bike or even sub 20 with a smaller battery . Could that be achieved on a L size bike ?
Je vais probablement installer un ampli de 360 W, un pot d'échappement Vorspung Smashpot sur un boîtier Zeb et une résistance Vivid Coil Ultimate, en configuration LX Leverage mais avec un montage Mullet. Je suppose que le vélo pèsera environ 20,5 kg… Quelqu'un a-t-il déjà testé cette configuration ?Il existe quelques domaines où l'on pourrait prendre du poids sans nuire aux performances, comme :
- un ressort hélicoïdal plus léger ou un amortisseur Vivid (j'adore cet amortisseur)
- cassette / manivelles
- disques de frein (les SRAM HS2 sont vraiment lourds)
- une meilleure paire de roues.
- batterie plus petite (dans certains cas, une batterie 290/360 pourrait suffire)
for sure with a 580 instead of the 360 w battery there is near 800g wheight to add .that's why I will order a 360 for the fuel+Quelqu'un ici a-t-il déjà essayé les deux ? J'en ai vu un en magasin et il m'a paru nettement plus lourd que l'EXE d'origine. Je me demande si quelqu'un pourrait me donner des détails sur leur géométrie respective. La puissance ne m'intéresse pas vraiment, je trouvais l'EXE déjà très bien.
I maybe wrong but unless there is a new 360wh battery from TQ, the 2nd Gen Fuel+ is not compatible with the older 360wh battery as its slimmer than the 580wh?for sure with a 580 instead of the 360 w battery there is near 800g wheight to add .that's why I will order a 360 for the fuel+
Not sure I understand you, but the 360wh and 580wh are interchangeable on the Slash+. As far as batteries, seems more of a length change than a profile change.I maybe wrong but unless there is a new 360wh battery from TQ, the 2nd Gen Fuel+ is not compatible with the older 360wh battery as its slimmer than the 580wh?
Must be some amazing trek engineering as the 360 is rectangle and from what I have seen the 580 looks like it has 5 sides with a distinct triangle profile on one side?Not sure I understand you, but the 360wh and 580wh are interchangeable on the Slash+. As far as batteries, seems more of a length change than a profile change.
So I think any bike that can take a 580 can take a 360 too. And so probably the 290 as well.
look at the fuel+/serviceMANUAL p22/28 you have the description of the adapateurs yo have to order with the tq 360W batteryIl doit s'agir d'une ingénierie Trek incroyable, car le 360 est rectangulaire et, d'après ce que j'ai vu, le 580 semble avoir 5 côtés avec un profil triangulaire distinct sur l'un d'eux ?
Ahh thank you for the clarification. The Fuel+ is not even released in my country yet so we don’t have the bike nor the information.look at the fuel+/serviceMANUAL p22/28 you have the description of the adapateurs yo have to order with the tq 360W battery
Old picture, 360wh (L), 580wh (R), doesn’t show the profiles but you can see the length/widths.Ahh thank you for the clarification. The Fuel+ is not even released in my country yet so we don’t have the bike nor the information.
Good to know it’s just adaptors!
I have put 27.5” x 3” studded Wrathchild tires on my Fuel ex-e. Not sure if the Fuel+ clearance is identical, but it should be very similar. Clearance for me is pretty tight… about 4mm on each side. No rubbing yet, but I’m also not exactly railing corners in the conditions that require their use anyways. The chain does rub the tire sidewall on occasion in the lowest 3 gears, but it hasn’t resulted in any problems yet.I'm seriously considering a 8 or a 9.7 to replace my 2018 Fuel EX. Maybe a bit odd question, but what does the rear tire clearance look like, especially width wise? I have a set of 27.5+ wheels with 27.5x3.0 spike tires (Suomi Tyres Fat Freddie), which are about as tall as a 29x2.4 but obviously around 3" wide at the height. It'd be nice to get some use out of the set.
Thanks, I think I'll just have to wait and see. IIRC the Fat Freddie is actually a fair bit bigger than a Wrathchild.I have put 27.5” x 3” studded Wrathchild tires on my Fuel ex-e. Not sure if the Fuel+ clearance is identical, but it should be very similar. Clearance for me is pretty tight… about 4mm on each side. No rubbing yet, but I’m also not exactly railing corners in the conditions that require their use anyways. The chain does rub the tire sidewall on occasion in the lowest 3 gears, but it hasn’t resulted in any problems yet.
J'ai commandé une version EX mais je vais y installer un levier MX, un amortisseur à ressort et un moteur Zeb 170.Bonjour, j'ai commandé la version Fuel+ LX.
Ce sera mon premier amortisseur à ressort.
Je ne sais pas quelle commande commander pour les petits printemps.
Je pèse 80 kg/176 lbs avec mon équipement.
J'ai commandé le ressort 475.
Quelqu'un a-t-il des commentaires ou de l'expérience avec le modèle LX ?
Merci
Across many bikes, I've had good success with this formula:Hello, I ordered the Fuel+ LX version.
It Will be my first Coil shock.
Not sure which spring tot order.
I'm 80 kg/176 lBS with gear.
I ordered the 475 spring.
Does Anyone have any feedback, experience with the LX model ?
sportandleisure.com
Oui, je connais Sprindex, je l'ai installé sur mes 3 derniers vélos. I ve order second hand springs ( 350 and 400) before ordering the sprindex oneEssayez aussi l'un de ces modèles, il permet de régler le raideur du ressort…
Sprindex Trail/Enduro Coil Spring
Sprindex Trail/Enduro Coil Spring Sprindex steel springs - the perfect choice for your riding experience! With an adjustable base spring rate and a progressive finish, the steel spring provides optimum performance and a better driving experience. Each set includes the spring, adjuster and 5...sportandleisure.com
Thanks for the formulaAcross many bikes, I've had good success with this formula:
rider weight (lbs) x Leverage ratio = spring rate (round up)
You can calculate the (generalized) leverage ratio by diving the travel by the shock stroke. So 160mm / 65mm= 2.46
176lbs x 2.46=432.96
So I'd start with a 450lb spring. But I think a 475 might be perfect if you ride aggressively and want to run lighter compression damping. I think the spring tolerances are easily +/-25lbs anyways. I think you should be good.
