Had my first ride yesterday coming off the G4 Levo. I am very happy with the range on this bike which was quite a worry coming from the bigger battery bike.
Things changed over stock:
- Fork
- Rear Shock to coil
- AXS 200mm dropper
- GX AXS derailleur
some info: I weigh about 103kg kitted up, I did a 21km ride with 900m of elevation in 1:20hrs. I had 49% battery left, most of the ride was done in tour+ with the stock settings turned down a notch. There was quite a bit of EMTB and TURBO in the mix for the heavier climbs.
I had the V3 bullit so can compare. I decided to go up a size this time and am on a XL frame. I'm 6ft on the dot and prefer a bigger bike, although the XL doesn't feel too big. The older bullit felt a lot smaller than it should have so upsizing this time was a personal choice for what I currently am after. I would stick to normal reach numbers for your correct body formation.
Coil - imo this suspension setup loves a coil, I was fitted to a 550lbs spring which I feel is not the sweet spot, bike rode in the travel quite a bit and sag was around 33%. I'll be moving up to a 575lbs coil later this week. Rode like a magic carpet though so it's always the toss up. I'm getting old so sometimes it's nice to just float along
Bike is so planted and fast going straight through the rough stuff.. I did struggle a bit on the sharper turns going down but not enough to dislike the ride, I just need to get a bit stronger.
Overall I'm very happy with the bike. The mods are defos worth the money.
