Cube one77 2025
Ive just ordered a SRAM GX Eagle AXS T-Type Bosch E-Bike Groupset to replace my XT. I'm hoping its an easy install :D also ordered the freehub for the wheel. One less cable to rattle :D
Check the rear shock mount if it's too tight it will creak under pedaling and it sounds like it's coming from the motor.
I thought this bolt was not suppose to be tight and there was not supposed to be any movement?
Anyone here besides me who still not have full 100Nm uppdate?
Bike: one44 hybrid sterio AT 2025
I took delivery of bike July 18 and still have not got 100Nm awable. I have tried following.
* 3 different phones.
* reinstalling the app many times
* tried almost every day go uppdate.
* two different dealers have tried using bosch computer and bike has latest awable sw.
Bike came new with 750w and emtb+ mode but I have still only 85Nm.
Both cube and bosch answers that I should try again on 2-3 days and now they don't answer anymore on emails.
Thanks for all advises.
After hunting creaks for a couple weeks this was the cause of the worst of them.... Especially when putting side to side tension on the frame (pedalling and or steering)
Even at 14nm as printed on the bolt it creaks. I've greased, used a touch of blue loctite and torqued it light and now the creaks have gone.
I was recommended on a other site that I should use carbonpaste and loctite and also ower tighten the bolt a little and let it sit for 24h before riding.
The one who's told me this said there should be zero movement in this area and now I'm even more confused 🤣
I've seen Jordi Cortez say that shocks should be allowed some lateral movement... The shock needs to be able to rotate in the yoke.
Tightening down too much doesn't make sense. Locking the bolt in without cranking it down seems ideal.
I have tired lube on contact areas and loctite on the treads and 14Nm also that's the way the bike was delivered with plenty of grease but it keeps creaking when bike is twisting.
Also sounds terrible when I stand beside the bike and push on left and right side on the paddles.
When I hold my hand on the area I can clearly feel it's the spot it comes from.
And I hate it 🤬
And I hate it 🤬
I feel your pain, I had this exact thing last week and gave up on a ride 5min into it because of the noise.
Listening the shock bolt in the yoke to ~10nm did the trick. Then I put the paint dots to keep an eye on it in case it came loose.
The next day I did a 3hr ride with varied "Canadian Rockies" terrain and it didn't budge and stayed quiet.
Yes it totaly destroy the ride listening to sound like this. Thanks for the advice
Anyone with the Fox Factory setup notice their suspension turning crappy after a couple of hours riding?
The Fork turns rough as hell, to the point I can barely hold on over repetitive roots.
I think it maybe the X2 shock overheating and sitting into the travel more taking the weight off the front.
Rebound is already fairly fast and it rides ok at the start.
It may also have something to do with grease in the air chamber... Going to try and clean that out this week.
I wonder if the reason sound ends when leaving the bolt a little looser and maybe also when the bolt is super tight and zero movement is that the sounds come from the contact areas slipping from each other and if they are free to move there won't be any sound but also if there is zero movement it should also be silent.
14Nm ain't working I know that for sure 😂
I had a hellish time getting mine updated to unlock 100Nm. Went round and round with Bosch/Cube and 99 Bikes (main retailer in Australia) for over a month. After a lot of misinformation and hearsay the best explanation was the serial numbers for the Cube bikes that came out of Asia (and maybe others?) were fouled up by Cube in Bosch's system and set to a mode which requires manufacturer approval before the 100Nm update unlocks. What this meant was I first had to visit my retailer for them to submit a "change request" through the Cube/Bosch portal, then return about 2 weeks later once the request was approved to allow them to unlock the 100Nm. Was told the app would "never work" to unlock the 100Nm when the bikes records were in this configuration with Cube/Bosch. How this could just not get fixed via records manipulation I have no idea.
In short it was a complete mess and have formally complained to all parties as no other brand seemed to suffer this problem. Made it very clear to Cube/99 Bikes that all their recent "In Flow app", "Ready for 100Nm" marketing was disingenuous.
Worth it though - the new more aggressive overrun is awesome.
It´s a 2 step upgrade. I´ve strugled some time with my one77 also and I don´t know if the option was already available from the 1st day. I understand it latter. First we have to do the bike firmware update (with the lateste flow app version) , then u have to return to app , enter again bike update and select the option to install the power upgrade.
Yeah I have tried all that many times,
I think it's something that's done incorrectly from when the bike was assambled and registered and that's the reason the software is not accuring in app.
Before the dealer delivered the bike the frame was swapped becouse of something found in delivery inspection,
You’ve probably tried it and it worked for me, but have you tried uninstalling the Flow app and then reinstalling it to get the torque update?
Definitely, out of curiosity I wonder if the dealership did the bolt replacement recall, I will find out when I dig into it this week.
The place I got my bike is in the process of sorting it out. It's Les's Cycles in Essex.
They are having a delivery of bolts this week and sending them out.
I live in S Wales so a bit of a chore if I had to send my bike in.
Well to start with thank you for long message.
And I think you are on to something, before bike was delivered to me when they checked it before sending it they found that the frame was damaged and I had to wait for 6 more weeks before delivery. Now after the message you sent me I asked them if they think it can have with the frame exchange to do and they asked me to check frame number and it don't match the invoice I've got from the store so maybe engine and frame is not matching the numbers they sent to bosch to release the 100Nm update. It's a long shot but biggest leap forward sense middle of July for me so big thanks to you!
Sounds plausible. My situation was (eventually) completely confirmed by Bosch and 99 (Cube were fairly useless). Was never going to appear in Flow app, despite Cube saying to "wait a few days". I watched them do it in store in the portal. A similar message comes up, worded like the 2nd stage of a Flow app upgrade everyone else got. Staff were as curious as I was! It's all Bosch's system, Cube just input data into it and skin it with their logo/bikes.
Speaking of the flow app / update. I am riding a new 177 currently in Switzerland and will be taking it to Hawaii in a month. I may wait until I get to the US to update in hopes that the process will recognize the location initially and allow the highest speed. There are no Cube dealers where I live if there is any issues. So...
Does a VPN work for registration in the US from Europe
If I update in Switzerland will it allow switching to the US speed when the bike is located there.
Do I need to get the update here so I have dealer support for any potential issues.
Thanks in advance for any thoughts, and don't get me started on how I will manage storing a battery here and finding a way to ship a second battery to Hawaii.
just been having a look at the 2026 SLX online (I have a 2025 SLX). UK RRP stays the same at £4499 but the spec now includes the Kiox 400C display in the top tube, Continental rather than Schwalbe tyres, matte blue instead of black, probably a few other minor changes. I'm a little surprised they kept the price the same, it already seemed pretty keen value without the 400C. But perhaps that reflects the state of the market?
again, Interesting to note that on the 2026 bikes, Cube's still using the adapter plate for the new Kiox 400c!
Decent colour that blue and I'd have ordered that instead of the black.
Interesting that they've shod the new bike in Conti's too.
Interesting twist with the AT models too. They retain the Fox Factory suspension and Schwalbe tyres but, the Kiox 400c display replaces Purion 400, SRAM XO T-Type transmission replaced by Shimano XT Di2 (no mention of auto shift, but should be possible reading Bosch’s stuff on this), and Bosch ABS Pro added to the XT brakes. Given the price is the same, that’s an even more amazing package.
would like to try the ABS to see how 'different' it is
Are the new XT brakes worth it over the old ones?
Probably only marginal differences. The addition of ABS on the other hand should be very useful, especially in the race mode that allows the rear wheel to lift; should make enduro turns easier/safer.
I guess a small frame change is still a frame change, maybe not easy to justify the cost. I notice the new AMS 177 doesn't need the adaptor (or maybe has a slimmer adaptor, I can't quite tell), picture shows AMS on left, 2026 Stereo SLX on right
Quick question on the crank arms. Is the correct fitment the bosch 5/isis narrow ebike cranks?
Justed fitted a set of pinned 145 cranks and the dont sit flush to the circlip as the cranks removed did.
    Join 43,137
