Cube one77 2025
For those of you with the 38/Float X2 Factory set-up on your One77 - And I know this is somewhat subjective ;) - Where are you finding the suspension works best? Bit firmer, bit plusher or right on the 20%/30% sag range?
I'm 250lb naked so always have "fun" setting up suspension, but I'm struggling to find the sweet spot right now....
I’m 93Kg (in birthday suit) and after using a friend’s Shockwiz for several weeks with my XL AT variant (FF 38/Float X2). I landed on the following:
All numbers are clicks out anti-clockwise from max damping/compression (all the way in clockwise).
Forks (just over 20% sag)
89 psi
3 Volume spacers (stock as the bike comes)
LSR 6
HSR 4
HSC 10
LSC 10
Shock (30% sag):
215 psi
4 Volume spacers (4 max -bike comes with only one volume spacer)
LSR 6
HSR 3
LSC 4
HSC 4
I can get a 500mm standard bottle in there. Did yours come with a 175mm transfer?
I bought a YT Thirstmaster 4000 with 600ml and Fidlock. Fits good on my former Fidlock system.
Note that the YT bottle comes without any fidlock hardware, so I recommend buying the 450ml standard bottle as well to get the base and bottle mount, and also swap out the lids as the standard one is nice than the YT one.
Well my motor cover keeps unclipping from the back when going over rough stuff so I’m hoping one of these will help. It unclips then rubs on the chain then knocks the chain off lol. They should have put 2 screws to hold it not one.
I had the same trouble after a few knocks. I think it must deform a bit. Replaced with the AVS one and it’s been fit and forget ever since.
The coil. Small bump on the fork is night and day better then the base 38’s. The bike feels so much more planted.
unless I find a cheap orange stem.
Is £35.99 cheap enough?
They look interesting.
Some food for thought whilst I'm off. Can't ride for 2 months now due to broken collarbone so plenty of time to look at upgrades. Need to check my one77s frame as it took a fair whack
Ouch. Wish you a Speedy recovery. I’m off work for 2 weeks so going to try and get some riding in. Was on about going Cannock tomorrow but probably keep it local instead.
Wish you a fast recovery man. I just removed the metal plate from my collarbone a week ago. Some advise -start the exercises as soon as possible, that will speedup your recovery.
Cheers I've heard great things about Cannock especially for off-piste
Loving yours I take it? (Presuming it was you who posted these a while back)
Yes….. well, until I went in for my ACL reconstruction op and now I just have to love looking at it in the garage when I hobble in to grab another ice pack. I got the 40mm length version, which worked exactly as I’d hoped to slightly shorten the reach and hit the Goldilocks point, after I’d sized up to XL when I found the L just a bit too small for my liking. The 50mm length version matches the length of the Cube one fitted, but doesn’t have the rise that the Cube one does. Checking around £36 seemed to be at least half the price anywhere else were selling them for in the UK, so was a no brainer to me.
Could I fit a Garmin 540 on it? I have to use a bar mount on the cube stem?
If you’re talking about one of those quarter turn Edge mount top cap thingys, I can’t see why not. The height of the top cap, plus the rising shape of the underside of the Edge units, should keep it clear of the stem clamps when twisting it into place.
Yep it certainly hurts! How long until the bone healed approx?
I started some physical activity in 1 months, in 3 months went ski-touring, started biking in 5 months, went to a bike-park trip in 6, removed the metal in 8. Plan to start riding in about 2 weeks
Hi I am new here and ordered my first ebike (one77 SLT) which I did zero research on until now. I have a couple questions to ask if you could help me out.
Is the BB height really that bad ? I ride alot of steep tech and bike parks and don't want to be caught out while shifting.
I am 5'9 and ordered a medium which I my current bikes are.( nukeproof giga 297 and the new jekyll) I belive im very much in-between sizes. What's your experiences either way?
Sorry for all the questions, I dont really want a bike that I have to change parts on to make it safe.
Thanks Paul
my Stereo 160 in size L had pedal strikes
I ordered the M and will add 150 mm cranks >>> Why?:
look at the table attached .. The M wheelbase is 30 mm shorter and the same components >> this should result in a bit more lee way.
    Join 43,147
