John_likes_bikes
A lot of the rattle people hear is something small in a big space between thier ears. If you catch my drift
I am also amused with ,multiple peoples enthusiasm for skinny down tubes. So much form over function.....
I my world of function over form. Skinny down tubes and big batteries mean increased forward and high C of G and worse handling characteristics. I prefer shorter fatter batteries which give a lower C of G an reduce forward weight bias......
Is it motor inefficiency or just more power being outputted so the rider has used less energy at the end of the ride?
The additional battery usage seems to be inline with the additional power output.
Also a full power full turbo ride is fairly inefficient for battery usage. I could crank the same ride and improve the efficiency simply by flicking down modes when there is no more or minimal speed to be gain burning turbo.
Me.PS. I know some don't give a crap about this stuff.
I simply don't care. Asthetics a well down the list for me.I don't know, all the fat tubed frames are pretty bad looking honestly. Sure, you can't see it while riding but dang, that Spectre is just so sexy looking.
My point being it may not be motor inefficiency but simply rider using less effort to do the same session.YTBD.
That said, I'm a strong pedaling SOB (this week anyways, as it seems to vary a lot) and I don't want the experience to be too easy.
George already hit his max speed on the old 750W Bosch, and the extra DJI power isn't making his ride any faster. So, then the question becomes, how easy do you want pedaling your e-bike to be?
The accurate comparison is to set the dji up to the same outputs as the bosch then do the loop. So what comes back, I would bet that it would be similar battery wattage used to the bosch.
The different in full power mode between the two in this test that op used more legs and lungs on the Bosch and less on the DJI. That is an operator decision not a motor inefficiency issue.
The physics reality is there is X work to be done to move a human bicycle around X loop. With more or less motor power is used and less or more legs/lungs used.
Needless to say, i'm not loosing sleep over not having DJI Crestline. I was a bit annoyed for a little bit that i missed out by 3 months. But then as I dug into it, I've realized I still have the better set for what I want. When I couple my 400wh battery up I have the lightest best handling Crestline set up and the makes me grin...Maybe, for sure. But what if the nature of the Avinox motor can't be turned down to ever feel natural and use less battery?
Also, I keep posting this, and hey, maybe it's just German favoritism.
But once again, here in this very review, 30 eMTBs in Our Huge 2025 E-MOUNTAINBIKE Comparison Test: What’s the Best eMTB of the Year? in a section titled Vertical Range Test, using a smooth climb, power pedals and a fixed cadence, the PRE-updated Bosch had both faster climb times AND was more battery efficient than both DJI bikes. This was in spite of the Bosch bike being a pig and the DJI bikes both being lightweight. I think what happens is that at the higher cadence and input watts that they tested with the DJI derates and the Bosch is effectively more powerful. Interestingly enough the watts used per climb in that test (about .45/ m for the Bosch & about .50w/ m for the DJI) for the motors almost exactly matched what George has experienced with his 2 Crestlines.
Right now with id go bosch, because dji dont have the local support or battery options that I wantIf you did not currently own a cheat bike, and Troydon texted you and said, "I have a Bosch and an Avinox frame is your size, which one do you want?" you guys know you're gonna pick the Avinox variant.
I'm not buying all this efficiency and COG rationalizing talk.
Oh it rattles fo-sho.. Quite an alarming first ride TBH. Does seem to have quited down a bit.I'm super sensitive to bike noise. I'm willing to bet over 50% of the riders will report no rattle at all. I can never go back to a fat downtube bike again. I love the looks of this bike.
- Once you figure out the correct PSI (it takes a little trial) you'll never go away from Radials. That US in the rear might last less time than Maxxgrip, the soft will do you better and you won't sacrifice much grip.* My Maxxis DHR2 DD Maxx Grip is completely done after 450 miles. Just switched to the Schwalbe Magic Mary Gravity Ultra Soft Radial/Albert Gravity Ultra Soft Radial and loving the combo so far! Actually surprised how nice these tires ride.
* My SRAM Maven organic pads are also done at 499 miles.
Got anything positive to say other than range is good?Here is a quick update after 499 miles.
* Avinox display screen did not fit tightly into the frame. If you tap on the bottom of the screen it will make a knocking sound. I put a couple layers of electrical tape inside the frame so the screen fits tightly now and doesn't knock.
* The Avinox speed sensor cable was making noise inside the frame (rear triangle). I had it attached to the brake line which caused it to bind up. I now have the brake line and speed sensor independent and no more noise.
* I started to hear additional knocking from the motor. Found that the motor bolts (both) have come loose. Torqued the bolts and all good now. The suspension pivot bolts also had to be torqued back down.
* The new Rockshox AXS dropper post is stupid. When not fully down or extended it knocks really bad. Had the older version AXS dropper laying around and swapped for that.
* Can ride 30 miles/5,000ft in Trail and 25 miles/4,000ft in Turbo. Range is good. Also done these rides on 95 degree days without any overheating issues.
Hands down the best bike I've ever ridden. I've never felt so comfortable/confident on a bike. The grip is so good. The suspension kinematics are perfect. It has exceeded my expectations. I'm going to cancel my Forbidden Druid order and get another Crestline Avinox bike when they release the next batch. Sounds like the motor rattle will be gone on all future bikes.Got anything positive to say other than range is good?
PS What a machine. 800km already? you pound some serious milage.
I read that Avinox fixed the motor rattle issue in a MBR article recently. Sounds like some current bikes are being shipped with the new updated motor as users are saying the motors are silent.What have you heard about this rattle thing?
I know that you have some inside info for us.
Safe to assume that you like a LOT of power and have no issues with the power delivery of the Avinox motor in comparison to the Bosch?
No issues with my new AXS Dropper, makes zero noises or knocks and it's a long boi 250mmHere is a quick update after 499 miles.
Hmm, I might send it in for warranty.Mon issues with my new AXS Dropper, makes zero noises or knocks and it's a long boi 250mm
"Active RIde," it's a feature not a bug!Hmm, I might send it in for warranty.
If you raise the post 1/2 way and press on the seat does the seat squish a little? Mine does squish but makes a top out sound hitting the bottom and top of the stroke.
My EP801 and Bosch Gen 4 Race motors all rattle a bunch. My Avinox motor rattles about 1/2 as loud as those. My brake pads rattle louder than the motor.The side by side video from last week (?) sure looked like two different Avinox motors with one that would definitely make a lot of noise on the trail. Question is, is that noise the rattle everyone is hearing and are there Spectre's with 2 different motors, if there are actually 2 different motors?
I feel like I'm a terrible judge because my ep801 is either quiet or doesn't bother me and people have been complaining about motor rattling on those for years. Damn, I need my shock back from tuning so I can get my Spectre out on the trail!
The active ride is nice. The knocking sound not so much."Active RIde," it's a feature not a bug!
It does the squish thing as designed but doesn't make any top out soundsHmm, I might send it in for warranty.
Wish I could get that rang out of tires.* My Maxxis DHR2 DD Maxx Grip is completely done after 450 miles. Just switched to the Schwalbe Magic Mary Gravity Ultra Soft Radial/Albert Gravity Ultra Soft Radial and loving the combo so far! Actually surprised how nice these tires ride.
there’s your problem, switch to conti dh tires, they last so much longerSchwalbe
I’ll give them a shot when I go through my Schwalbe stash. Maybe I can snag some Continentals with Labor Day sales.there’s your problem, switch to conti dh tires, they last so much longer
