When you write to the controller, are you able to re read those values once you turn the motor off and on, as in the motor must overwrite those values from its firmware or ignore all the parameters which seems a bit strange ?35kph max speed, tested both with low cadence on flats roads and high cadence with steep climb
Almost the same as my motor.Yes it works from base 750mV up to 3200mV
CAN signals are just that, CAN signals and yes if the protocols are followed, then communication between devices will ensue. If however Bafang uses a non standard call then although the CAN signals have been sent, they may not have been received correctly.Tools under the hood using the same methods of communication over CAN.
Are u 100% sure that u feel a difference ? Because u are the only one who's claiming there is one.
Also i'm in contact with guys who's is process of reverse engineering the firmware and they checked code of your firmware version and they claiming that spd table is also hard coded there.
Mmmmm bold statement. Let’s have your dynometer test results, repeated over many cycles, in written form so that they can be peer reviewed.I also tried adjusting the motor assist parameters some time ago, and I can say with full certainty that they do not cause any noticeable changes!
All you need to do is flash different firmware versions as a test, then check the values entered in the fields like "START TORQUE VALUE", "MAX TORQUE VALUE", etc., and finally test how the motor behaves in practice — I assure you, the difference is not subtle.
I’ve tested all available firmware versions for 48V, 43V, and 36V, and honestly, even Pinocchio would feel the difference.
Thanks for responding, how high is very high? My cadence is about 90. Also, is the 4.5 ‘road’ firmware the same as I already have on the motor As mentioned above? The name is the same apart from the _eroad_230317.bin at the end? ThanksTry it ,it is completly different firmaware ,very powersaving ,but Your cadence must be very high to get power
I have just remembered, the original battery lost capacity too quickly after I had disconnected and reconnected the bms as it appeared to have gone into sleep mode. I got a replacement battery thinking the original one was faulty. Could I have somehow created a problem with controller on the motor causing it to run too powerful which is why battery consumption is poor?I have the M820 43v 13A motor with firmware CRX30PC4313E102004.3 The battery is a 44.4v HY.12S2P 10Ah 444wh. The firmware is too powerful! It feels like it’s on boost all the time, there is very little difference in support levels 1 - 4, the is a small increase in power when on boost. My battery capacity is used up very quickly, consequently my rides are quite short! I have best pro, I can flash new firmware, change start up angle and acceleration, speed limit and current limit percentages, but nothing else. I have changed the current limit but it just changes when assist starts, the amount of power stays the same. I have the 4.5 firmware, is it any better? Has anyone used it yet? Thanks
bestst tool (1.2.20) login and passwd? my login and firmware from here - the limit cannot be changed more than 25 km speed (First tune how you want it in besst pro, then use old version of besst tool(1.2.20). There you can set speed limit to what you want.
Download here:
Github
THX.
That is 43V 10Amp firmware, better of look for 43V 13Amp firmware. I'll post U in the morning 4.5 firmware with 13A.Today I received 1.5_eMTB_230721 (43V) firmware from Jean. Is this an old firmware? isn't the latest 4.5?
Just press the power button 4x while riding and You will see how many Watts is consumed by the motor.Hi thanks, for respondin. I have found CRX30PC4313E102004.5_230721. and have put that on. Is it the same 43V 13amp as mentioned above? I had done a short ride with it and it’s much better than what was previously in the motor? I will do a longer ride to test it more, especially for battery consumption. Question, how can I tell the difference in 10am v 13amp firmware? I guess it’s shown in the letter/number sequence? Cheers
Brill, thanks for the infoJust press the power button 4x while riding and You will see how many Watts is consumed by the motor.
In 10A softwara it will be about 450W max and on 13A software about 580W.
PC4313 is 13A
PC4310 is 10A
4810 is 48V and 10A
and so on...
Regards
@Dado Would it be possible to share the firmware:Here it is. Let us know if you find some bad behaviour. I am marking it in a firmware names.
I think that can be found in post #11.Would it be possible to share the firmware crx30pc4813e102004.3_230214.bin
So this one from #11 is written in Chinese/Japanese and when you install the file it says 4812EI think that can be found in post #11.
