Sorry, I haven't checked your messages recently because I'm on holiday.
Happy Chinese New Year to all the riders!
About the cover of head set, we have a new cover for it, check the photos,
also I will share the 3D file of motor's bottom cover, if someone's cover is brokenm you can get it from us or make it by youself.
new cover for head set  (3).jpg new cover for head set  (4).jpg new cover for head set  (5).jpg new cover for head set  (6).jpg new cover for head set  (8).jpg new cover for head set  (12).jpg new cover for head set  (13).jpg
Anyone interested in buying this?
43V. With bafang tool speed unlocked
OhlinsTTX1
Has maybe 100miles on it
$1500
Hello.
I'm trying to find a higher-capacity battery for this ebike (I currently have a 410w Bafang battery).
I've located Agazzicini Bikes, which has higher-capacity batteries for this ebike model.
They're asking €710 for a 645w battery, plus charger and shipping.
As you can see, this price is either right or too high. What I'm told is that the BMS might not be entirely accurate, as it wouldn't display the correct battery. Regards.
Hello.
I can share ready solution for 250wh range extender
IMG_20250214_214200658.jpg IMG_20250208_193328574.jpg IMG_20250214_214110540.jpg
What do you mean by “ready” please?
Ready to sell and ship?
Ready for your experiment?
Willing to share!
i mean if You are a DIYer You can "copy and paste" this project this is 12s2p extender, 24 18650 cells and smart BMS perfecly fits this fidlock bag ,I m using dual battery converter from Aliexpress that alows me conect and disconect at any time
Selling my LCE930 medium frame, complete bike. All new parts, except the fox 36 fork and only tested in driveway. TRP brakes, SRAM GX 12 drivetrain,PNW 150mm dropper. Picked up a different ebike waiting for parts on this bike, so need to sell. Has the newest headset from lightcarbon for cable routing. $4000
IMG_7841.JPG IMG_7842.JPG IMG_7843.JPG IMG_7840.JPG IMG_7844.JPG IMG_7845.JPG IMG_7846.JPG IMG_7847.JPG IMG_7848.JPG IMG_7849.JPG IMG_7850.JPG IMG_7831.JPG
Hi all,
Today, during the ride, I received ERROR 21 and motor refused to work. I checked, and it should be a problem with a speed sensor. It looks like the wires in the cable got damaged. If I wiggle the wire that goes from the chain stay to the frame, it sometimes work a bit, especially if I am not on a bike. But If I sit on a bike it stops working. This is why it looks like, the bending on the wire on that point caused the failure. I already ordered new speed sensor from AliExpress, but it will take at least 2-3 weeks for the sensor to arrive.
To me, the path of the cable looks quite unnatural at that point. When suspension compresses, it essentially pulls the cable from behind the motor cover.
Anybody else had issue like this? What would be the best way to prevent another failure?
Would anyone like my HukTek custom titanium motor bolts I had made for the lce930? I'm parting out my bike.
These save 100g vs the standard steel bolts. Plus they're just cool! 😎😎
$150 USD shipped in the United States. I'll ship overseas if you pay postage.
Hi all,
Hello.
The same thing happened to me.
When the suspension is compressed, the cable stretches and comes loose from the motor connector.
I solved it by making the engine guard entry hole slightly larger, so the cable would have more travel.
I also mentioned this to LightCarbon, so they would take it into account and provide a cable a few centimeters longer.
Regards.
I would very much like to know the parts you used please
24 18650 cells litokala aliexpress
JBD smart bms aliexpress
fidlock bag any local bikeshop
spot welder
hot glue gun
1m 16AWG cable red and black
0,15mm nickiel strips
XT30 conector
xt 30 socket 3d printed (can share project)
aliexpress dual battery converter
spot welder
hot glue gun
XT30 conector
Sorry but if you have links for the above would help a lot. Plus share the 3d print yes please
You can buy from JIM, you can make it yourself, you can also print it on a 3D printer - the cover design is on this page.
Hey all, I went looking for the more advanced Go app to get at the power settings. Installed the app. It offered an over the air update for the bike, seemed like a no brainer....did that. It now is giving an error and will not run. App connects and shows all the connected info but it throws this error 07 Bus over voltage.....did I install an incompatible firmware or something?
Do I need to get hands on the BESST tool? is there an over the air way to roll back the firmware?
Hi
I had a similar problem, I thought something had gone wrong with the controller but couldn’t find wrong, I flashed over the original settings using my K1 flash tool and problem solved.
Hi
Don't have that tool.....is a basic USB UART cable suitable?
Write what engine software you currently have installed and what battery you have (what voltage). The cable you indicated is incorrect, you will need Besst Tool which works on the CAN bus.
yes I figured that out, Can bus cable needed. Battery and motor are 43V.
Screenshot_20250614_181846_SwiftFlow.jpg Screenshot_20250614_181854_SwiftFlow.jpg Screenshot_20250614_181903_SwiftFlow.jpg
You have uploaded firmware for a battery with a nominal voltage of 36V, but your battery has a nominal voltage of 43V - this will not work. You need to find someone from Beest Tool to upload firmware for a 43V battery.
    Join 43,104
