3) 75Nm is enough for me in most solo riding conditions and some group riding scenarios, if not hardcore peeps. (One caveat: Bafang needs to firmware update to add the original superboost 85Nm mode and stronger eco and walk modes.). I've never had a problem in turbo overheating, but I do use it sparingly for up to 5 minutes on a steep.
What engine firmware did you install to increase power?
None. I'm hoping Bafang will do a firmware update for the M820. Max is still 75 Nm.
When Bafang first launched the lightweight motor a few years ago, they advertised as 75Nm max torque, but also had a mysterious short superboost mode...a few us here in jest just picked 85Nm as a theoretical max, in part to be categorized as a small, lightweight, truly 85Nm full power motor.
My desire was that someone at Bafang was listening (maybe reading this thread) and would put out a firmware update to compete with updates from Brose, Bosch, and Shimano, who are in turn dialing up their torque to compete with the DJI-Anivox 120Nm.
But I think Bafang has so much else going on with their other motors, such a firmware update is unlikely. Bafang seems fairly insulated from consumer feedback directly.
Bottom line: there is NO superboost 85Nm power mode firmware update planned that I'm aware of.
C'mon Bafang, give us an 85Nm superboost upgrade!😁
Looking at the extend battery connector it is 4 pins, my cef50 is a simple 2 way female connector.
Weight of the size 15 frame and weight of the frame with a 700Wh and 480Wh battery. I'm currently unsure which battery to order. There's a difference of 1280 grams.
Those of you who have the 480Wh 48V battery, what range are you getting? I have to make a decision.
View attachment 156916 View attachment 156917 View attachment 156918
✅ Rider weight
✅ Terrain normally ridden (big mountains v. rolling hills v. flat and hard packed v. loose)
✅ Peak torque is higher at 75Nm on the M820, so of course the higher power modes use more juice quicker.
Peeps kind of figure higher power modes will rarely be used in the begining, but the CEF50 is kind of addictive, even in controlled bursts. Its way more agile over the heavier, true full powered rigs. Also, it's fun to charge like the lighter analog in the twisty singletrack. And few really enjoy a crawl up a boring, tough fireroad. So, you'll likely burn more than you realize even on a generic trail. All good reasons! IMHO😁
A smaller 480Wh battery for almost a full powered bike is very doable if your light, riding flatter, groomed more XC trails, and gravel roads, probably running thinner and faster tires, Lastly, If peak torque was 50-60Nm, the smaller battery makes more sense and is more efficient.
You could also build an battery extender connection. This gives options.
For what it's worth...🍻
i
i'm old (64), heavy (100 kg), i doing 30 km 1500 D+ with the 480 and i keep +- 30% of the 480w. initially i have purchased the 700 and i have change it because i never consumed more than 40 %. But i use very lower the boost mode.
✅ Rider weight
Peeps kind of figure higher power modes will rarely be used in the begining, but the CEF50 is kind of addictive, even in controlled bursts. Its way more agile over the heavier, true full powered rigs. Also, it's fun to charge like the lighter analog in the twisty singletrack. And few really enjoy a crawl up a boring, tough fireroad. So, you'll likely burn more than you realize even on a generic trail. All good reasons! IMHO�
For what it's worth...�
Hello, I weigh 72 kg and I am in shape since I practice MTB and lung cycling, my terrain is XC marathon, some hard climbs but 80% compact terrain (I was thinking of mounting up to a 130 or 140 mm Fox 34 since I am not going to get the most out of the 160 which is the one I have bought) 2.35 barzo and mezcal XC UCI tires, I have bought all the components and weighed them and with the 480wh battery it weighs 16077g and with the 700wh 17353g it will always be a little more or less than those weights, Jean is investigating bringing to market an extender that goes in the 280wh frame and weighs 1163g, I put a photo, I have to decide on one of the two batteries so that you can send me the frame, motor and battery kit, let's see if more people put their autonomy with the batteries 480wh 48v
✅ Rider weight
Oops! A big one that is forgotten is reserve battery cut off on all M820 CEF50 batteries is 20%. This is unusually high set by Bafang. (My Bafang M600 is also 20% but my other e-mtb is the Bafang M620 at 12% but it's a custom battery/BMS) where it kicks higher power modes down to eco power mode. Eco mode on the M820, like the walk mode is weak. Good thing the CEF50 is lighter but walk mode does serve to assist standing gear-change mode., so it's not useless. One of the only few complaints.👍
View attachment 156938 View attachment 156939
Yeah, a 280Wh battery extender would be great!,👍
hi everyone. I have a Cef 50 front triangle in XL size. I would trade it for M, L size. frame new never painted. or I'm buying a m, l front triangle. EU countries only. thanks
What's everyone's thoughts between the 36v 720wh Battery or the 48v 700wh Battery.
Have ordered the 36v but I'm wondering which is more popular.
Both are available as extender batteries. It is the 43v that is odd. The 48v will be heavier.
(not from SZZS) Third party batteries still need a new connector to handle both the charging of the internal battery and the power-in from the external battery. The charge port on the stock CEF50 is only designed for charging at 2 amps. Not enough to supply power to the motor.
Anybody in the know have more information on the SZZS specific battery extenders.
I'm wondering about cost, availability, and integration for both 36V and 48V systems.
Also, what is Jean Wang's email address again....it's been a long time since I contacted them. 😁
Thx🍻
34% tariffs put on Chinese goods in the US at midnight tonight.
Damn! SZZS was putting out their 36 V extender battery(280? Wh) next month.
Was $245 USD. X .34 = $83.3 more for $333.3 total 😜.
Granted still cheaper than the big boys like Specialized and Trek etc...but still💸💸💸!
Thanks very stable genius!💩
Hi guys, I'm interested in buying a cef50 V3 and I have some questions about the size. I'm 1,75m (5'9") and have an inseam of 81cm (32"). Do you think size M is the right size? So far, all my bikes have been size M.
I'd say the sizing seems to be a 1/2 size small. IMHO.
I'm 6'1" with 32" in seem (long torso). I use a large and kinda feel like I could of have gone up a size to XL.
That being said, the CEF50 has a nice and low stand-over top tube height. Personally, this is the by far the best frame geometry and dropper post insertion length I've used to date. The frame kinematics really shines for heavy trail-duty and light Enduro-styles!😜
Are you sure its only 2A? How it's possible, if they selling CEF50 with 4A chargers ?
My CEF50 came with a 2amp charger. Even 4 amps would not be enough to run the bike. 500w/48v=10amps
What autonomy are you getting with the 480 wh 48v batteries?
There is a variation of 1280 kg between the 480Wh and 700Wh batteries, both in 48V.
There is a certain kilowatts per kilometer used, that depends on how you ride and at what assist levels. The batteries are linear storage. So a 480whr battery will take you twice as far as a 960whr battery.
I don't quite understand what you're telling me
That is difficult because it depends on how many watts you put in, what kind of surface, temperature etc.
¿Alguien ha comparado el rendimiento de un amortiguador de muelles con uno de aire en este cuadro? ¿Cuál recomendarías?
    Join 43,212
