Re-grease if at or near service interval. I did mine only a few 100 km's from new using instructions from here and can not say it changed much but 1) now have piece of mind, 2) know that occasional sounds aren't anything serious and 3) assured it is properly greased.i’m removing my m820 to fix cable rattle. is there any motor maintenance that i could do whilst the motor is out?
i didn’t even know there’s service interval where can i find the instructions?Re-grease if at or near service interval. I did mine only a few 100 km's from new using instructions from here and can not say it changed much but 1) now have piece of mind, 2) know that occasional sounds aren't anything serious and 3) assured it is properly greased.
Nothing from the manu. that I am aware of but every 2,500km seems to be mentioned most. There is at least one very detailed instruction set located here.i didn’t even know there’s service interval where can i find the instructions?
Hi, I have the LCE930 ebike with the Bafang M820 motor.
How can I configure the motor parameters with the Bafang Go+ App, to get the best performance from the motor? Currently I have it like this:
130 w more ? please explain?
Hi,Actually you can set just Global Acceleration and Max power at each PAS level.
Current speed limit does have nothing with speed - it is max RPMs of rotor, leave at 100%.
Startup angle - how quick engaging motor after starting pedalling. 10 Degree is fine.
This motor does not support Assistance level (torque sensor sensitivity, only M510 FC2.0 and M560 is supporting so far).
But check for the motor firmware version. Bafang is sending 43v version with 10A max. You can flash there 13A firmware, which will give you 130W more.
On your bike display setting , set to display watt, as you pedal , you can how watt your motor output, try towing a bike behind and set to B on up hill climb. Then u can see your motor Max watt.Hi,
thanks.
I don't have a tool to update the firmware, and I don't know how to do it. So the only thing I can do with the APP is change the angle to 10 degrees.
With the App, I understand that it is impossible to change the firmware.
Saludos
Hello.
hello, never heard about this brand: where to source please, or is it only thru Forestal?supposedly the eondrive goes well with good power delivery for its 18kg of bicycle and 360Wh 51V battery, weight of 1.95kg, 170mm Q factor, 60nw, motor with titanium components and magnesium casing, more or less this m820
And only for them, too bad as the specs are promisingBafang designed the EON-Drive for Forestal.
I’ll keep watching as mine is coming soon!!hi everyone looking for some advice regarding what to do next first time building a e bike.
so i connected all the electrics up the other week motor battery headunit and the display turned on for about 20 seconds shows error code 30.
so i read most of the information regarding this setup on this forum and decided to purchase the bafang besst tool.
i have connected it all up today and this is the information it has displayed.
any tips would be greatly appreciate.
View attachment 156896 View attachment 156897 View attachment 156898
thanks for the reply i purchased the besst tool just to connect everything up and see what works and what dont and for future maintaince. when i plug the display into the tool i get this. the plug that goes into the motor i have made sure its fully inserted. ordered a new cable 1t3H just to see if its that.Error 30 - no communication or faulty communication on CAN bus between controller and display. Check cable and connectors if plugged properly till the end.
Besst wont solve this issue.
thanks the 1t3 H cable that goes into motor seems like its not fully inserted but i have pushed it in fully. ordered a replacement cableUnplug all your connections cable and plug in again , try several time if possible , both my bafang motor when news has all kind of funny connections problem but after few unplug, problem solved. Pls unplug the extension cable too.
I have seen ERR30 a few times now, always because of the cable to the display pulling out slightly. I get quite a bit of overgrowth dangling down onto the single tracks and it seems to pull that cable enough to slightly dislodge it.hi everyone looking for some advice regarding what to do next first time building a e bike.
Yes, Besst is powering up display, so will turn on.thanks for the reply i purchased the besst tool just to connect everything up and see what works and what dont and for future maintaince. when i plug the display into the tool i get this. the plug that goes into the motor i have made sure its fully inserted. ordered a new cable 1t3H just to see if its that.
am i right in thinking that if the controller is not showing on the besst tool is because eitheir the cable or controller is damaged ?
thanks for the information. i have the battery connected via the yellow socket and the green plug that goes into the 1T3H lead. that lead then goes to the motor and the display. you mentioned about turning battery on there is no manual switch is it just a case of using the button on the left controller ?Yes, Besst is powering up display, so will turn on.
If Besst wont read controller, then faulty cable or controller is gone. (Do you have main battery cabled and turned on? Motor is not powered from Besst.) But I must say, newer seen a brand new controller which was not able to read by Besst yet. They are testing it in a factory and flashing controllers at the end of production line.
That is good to know, I had to cut out from a sheet of paper gasket when I regreased mine! Thanks!FYI: M820 enclosure gaskets (the ones that are really easy to damege when greasing) are now available for sale at GreenBikeKit (www.greenbikekit.com).
