Bafang M500 and M600 motors
Thanks Dado!!!! Silly me!!! 😄😄
I just installed the throttle... Was not aware that the pas level affect also the throttle power....
Thanks!
Unfortunately M500 and M600 throttle worked according PAS. That was such a stupid idea from Bafang.
M510 v8.1 or 10.1 I discovered max speed on throttle is hardcoded to 32kmh
Guys, my M600 suddenly switched off and is effectively dead, checked all the wiring connectors and wiring loom for continuity, replaced like for like both on buttons and display all to what it would appear no faults. Checked the internal fuse and that checks out with max volts reducing to 3.5 volts when the on off switch is pressed. Seems powered up.
Taken the controller out expecting to see water ingress or a board fault but no suspected areas for a fault.
Anything else to look for before I order another controller ?
Does the led on controller turn on when you press power button? And then goes to blinking after boot up?
Thanks, not something I have checked, I'll reconnect the controller and have a look. What position on the board is the LED ?
If you wont see LED turn on, I would check/replace cables, connectors, buttons.
Mmmm no LED light. All the wiring loom seems OK as in continuity ( except 1 pin which I'm presuming is the 6V light, my loom hasn't a light output ) and I have a new DZ41 display, new buttons but not the DPC242 display to test with.
OK how can I test the connector betwen the loom and motor, without a strip down of the entire motor ?
Another question. When testing off the bike, as in motor, wiring loom, display on the bench, do you also need to have the speed sensor connected ? Its the one thing I haven't yet taken off the bike.
If only to test it no need connect the speed sensor, when testing on walk mode it just show error 21 after the motor turn for a while.
Hy dado i can see that you know very well about bafang i m facing to a problem that the m600 won t turn on .I got a new motor underwarranty .
So i replace with new motor and bike work good now . So i try to fix the broken one .
I order new controler . Not working .
I order new pcb and cable . Not working .
So i unplug torque sensor and motor and i get the green light flashing .
When i plug the torque sensor the green light stop flashing .
What this green light mean and can i start the display without torque sensor plug ?
thank s for you re help
Hello.
Green blinking light means controller had boot up successfully and no error. (form new controllers they have removed this LED - saved 0.01 USD :)
Yes, you can unplug torque sensor, but it wont help u, will be giving u error. Is strange it is not booting up with torque connected. Could be some shortage at torque sensor. If only wrong voltage output from torque it should give you error, but should be able to power on.
Do u have Besst? If you plug torque sensor, are you able to read motor over Besst? Let us know what voltage from torque is Besst reading.
I would try new torque sensor...
Hello.
Thx so even with torque sensor disconnected the screen should turn on if i understand .
yes i do have besst but besst not reconise it as the motor can t turn on .
I don t want buy a torque sensor new if the problem is from something else .
Yes, also without TS.
You said u have changed everything, right? So only sensor is missing. ;)
Try connect to Best without torque sensor connected and let us know.
Hey everyone. I hope there will be someone who can point me in the right direction - I am looking for a firmware for my M500 (currently CRX10NC3615i142017.7). The firmware should have a very weak support on setting 1 (like 50 to 100W) and gradually increase it from there. And, of course, it should not blow up the motor at higher settings. Do any of you use or know of such a firmware?
Yes, me and with it 17A FW.
Hi, I saw you are using a FW I was planning to install on my motor. My question is: how many Watts do you get on Level 1 support? I am looking for a firmware, that offers a very low Level 1 and 2 support - around 50-100W, not the crazy 390W I'm getting now. Also, have you, maybe, seen other firmware for M500, with this type of setup? Thanks in advance.
I was running it and it's like this: 1.2 approx. 300w 3.4 approx. 400w 5.6 approx. 600w 7,8,9 over 700w In the photo, st.1 is about 300w, it is difficult to take pictures with a mobile phone in hand.
300W as the lowest support - that is just ridiculous - the bike basically rides itself - so its either be driven around or turn off the motor and do all the work yourself. If I knew this was the case I would not have bought a bike with this motor. And there is apparently no way to change it either.
But you know it's the peak, with increasing speed the assistance decreases. I'm guessing you're not pushing it all the time. And you also have gears, I have no problem with that.
It depends what you looking for. Bafang is famous for higher power and less pedalling - we all get lazy from this motor. ;)
You can still update to M510 FC2.0. All is compatible and it is a good motor - you can finally set controller parameters: power levels, acceleration, support level, rpms, startup angle.
Btw., how is your power consumption after swapping to the 17A firmware?
I don't deal with consumption. My longest trips are about 60-80km with 600-1000vm and the 630Wh battery is fine for that.
hy after a month i replug the controler without torque sensor and this time the screen turn on .Why now and not before i have no idea .
So i test torque sensor plug the screen not turn on .
I change torque sensor for new one and this time the screen turn on .
So it s defently a torque sensor error .
I had 2 engin and 2 torque sensor error .
The bad thinks is too change the torque sensor we have to change the entire piece unstead of only the electric part .
Will be good if we can order only the electric part .
Thank s for you re help .
BESST Pro compatible 46.2 firmware found!
Here is the flashable M600 48V 46.2 firmware that can be adjusted with BESST Pro 😎 Have fun!
Be aware, all "Max. Power" levels are on 100% by default! You need to adjust them yourself!
CRX10NC4818i132046.2
Please report any issues, you might encounter with this firmware, in this thread!
Here is the flashable 46.2 firmware that can be adjusted with BESST Pro 😎 Have fun!
It looks like M600 48V firmware, doesn't it? Anything interesting for M510?
Thx almos there ...... any idea ?
    668K
