Bafang m820
Freda
97
92
Vaasa
Will it fit to the frame?
Well it is probably maximum, but posted in other thread this: LCE930
Basically a tape wrapped battery without case, bms needs to go somewhere also. It needs to be a tight fit or have some kind of fastenings to stay in place. Your idea would probably be a more safe option and still lighter then oem battery.
I still don't undestand the can bus connection. If you make custom battery without that and it works, then why they use the can bus in the first place?
brbr
463
244
France
Hey Guys, the motor vendor proposed me the besst tool for 100usd, it seems to be a good price, what do you think?
LAnton
483
395
Russia
The second motor has a different firmware. What has changed?
LAnton
483
395
Russia
If the 20% battery charge limit is removed there, then this is good. I will be able to check it after assembling the bike
mike_kelly
898
724
US
It is the point the BMS decides the battery is too low to continue without damaging the battery. So it turns it off.
LAnton
483
395
Russia
The motor reduces power by less than 20%. It seems to me up to 30-40% of the motor power. It is very annoying when there is a spare battery in the backpack.
brbr
463
244
France
I should finally receive my motor soon, custom clearance in progress! for the battery, I'm still waiting a date tho...
If it's in 2/3 weeks I can wait, if it's more, I'll go DIY
Dado
577
407
Bratislava
Guys, 1am I the only one with the direct mount and not the chainring spider?
Seems like steel teeth. :( Thats unlucky they do not sending spider, where u can mount good alu wide narrow chainring.
How is outer ring mounted to spider? Some screws from the back? Or just pressed?
Please put it on a scale. That spider seems to me quite massive.
