Cube Stereo 160 S 750 2022 Specs Modifications
BeBiker
663
404
Belgium
I mounted the toolbag to the saddle.
The front strap goes around the inner tube, no scratches or damage till now.
There's no other acceptable place on this bike.
rop12770
21
15
Portugal
Who expected this? 10% price drop.
Did they go from undercapacity to overproduction, or does everybody want the 2023 model ?
Here in Portugal we had a VAT decrease from 23% to 6%, starting in January.
That made bikes a lot cheaper now.
BeBiker
663
404
Belgium
Since the beginning, the bike falls out completely every +-100km.
No warning, no error, unrelated to asphalt, jumps, cobblestone,...
When restarting, that always works instantly.
The bike has been in the shop for this: Update, blabla, didin't change a thing.
Until last week, then it was unable to restart, sometimes falls out again after 5 seconds, falling out 10 times in a row,...
but I was able to make it home.
BeBiker
663
404
Belgium
Let's check for bad connections:
The original bashguard: >2cm of mud, sand, dirt
Upside down, the motor and connectors:
I cleaned everything, pulled out the connectors, cleaned that, problem solved.
Hanzzzie
213
96
Belgium
Btw... Mine had the same just shutting down without any errors/messsages... was the battery
happened after 30-40'ish km's, sometimes quicker, sometimes completely nothing happened...
also unrelated to road/forest/singletracks/...
BeBiker
663
404
Belgium
Did they give you a new battery ?
BeBiker
663
404
Belgium
Impossible to look up which derailleur hanger is mounted on our Cube.
They all go by names like: Cube standard, Cube 160, universal,...
So I took it off, it's this one: Sram UDH
Now I'm ordering spares, the speed sensor is the 615mm one:
The power cable is the 500mm one.
I need this in case one day I need warranty.
E-MAD MALC
310
157
EAST SUSSEX
The crank arms are 165mm long.
Touching the ground with the pedals is a brand new experience to me :oops::oops::oops:
I plan to install 152 or 155mm.
Inbetween the cranks there is 153mm, Outside between the recessed surfaces +-175
This seems to fit:
Any experiences ?
Hi be biker
I when for 160mm e thirteens on mine seems to work OK for me
be biker
E-MAD MALC
310
157
EAST SUSSEX
This seems to fit:
Any experiences ?
Hi
Be Biker
I got the derailleur hanger from this company
BeBiker
663
404
Belgium
Funny for my Cube 537113 they indicate the Radon Derailleur Hanger 8651, while the Sram UDH is installed.
Maybe compatible with both, and they installed another one due to the 2021/2022 stock shortages?
Your list can be very useful for the bearings also.
Arminius
403
618
Rhein-Ruhr Delta, Germany
Thank you. Having also a Cube 140 SteHy I started looking for a spare part when reading your post and got frustrated like you as even our German shops are not providing good guidance for looking up.
The table was found as linked pdf via gooogle but unfortunately there is no source info. Nevertheless it looks proper.
BeBiker
663
404
Belgium
  • Derailleur-HangersBearing-Sets_2022.pdf
  • CUBE-Bearing-Sets-MY2022.pdf
BeBiker
663
404
Belgium
Those are Cube numbers of the set, which contains bearings, spacers, bolts.
Didn't find any further dimensions info, but at those prices I think just ordering the sets.
Arminius
403
618
You get a new port and cover as a waranty at your dealer. Much improved version.
Do you have some more details what has been modified vs. the „old“ version:
BeBiker
663
404
Belgium
I always was a bit underwhelmed by the split pin in the Deore BR-M6120 MT520 brake caliper.
The Deore XT brakes, and even the Tektro brakes from my Decathlon Rockrider have a bolt with a clip on it.
Then stumbled upon a tread about the conversion on this forum:
On the forum there was some confusion about the thread size, it's definitely M4
Scientific aligning, angle correction and positioning
Bolt and clip in place, ready to go !
