Cube Stereo 160 S 750 2022 Specs Modifications
I mounted the toolbag to the saddle.
The front strap goes around the inner tube, no scratches or damage till now.
There's no other acceptable place on this bike.
Who expected this? 10% price drop.
Did they go from undercapacity to overproduction, or does everybody want the 2023 model ?
Here in Portugal we had a VAT decrease from 23% to 6%, starting in January.
That made bikes a lot cheaper now.
Sad that your goverment still steals 6%.
But good news, it has to start somewhere !
Since the beginning, the bike falls out completely every +-100km.
No warning, no error, unrelated to asphalt, jumps, cobblestone,...
When restarting, that always works instantly.
The bike has been in the shop for this: Update, blabla, didin't change a thing.
Until last week, then it was unable to restart, sometimes falls out again after 5 seconds, falling out 10 times in a row,...
but I was able to make it home.
Let's check for bad connections:
The original bashguard: >2cm of mud, sand, dirt
Upside down, the motor and connectors:
I cleaned everything, pulled out the connectors, cleaned that, problem solved.
Btw... Mine had the same just shutting down without any errors/messsages... was the battery
happened after 30-40'ish km's, sometimes quicker, sometimes completely nothing happened...
also unrelated to road/forest/singletracks/...
Did they give you a new battery ?
Impossible to look up which derailleur hanger is mounted on our Cube.
They all go by names like: Cube standard, Cube 160, universal,...
So I took it off, it's this one: Sram UDH
Now I'm ordering spares, the speed sensor is the 615mm one:
The power cable is the 500mm one.
I need this in case one day I need warranty.
The crank arms are 165mm long.
Touching the ground with the pedals is a brand new experience to me :oops::oops::oops:
I plan to install 152 or 155mm.
Inbetween the cranks there is 153mm, Outside between the recessed surfaces +-175
This seems to fit:
Any experiences ?
Hi be biker
I when for 160mm e thirteens on mine seems to work OK for me
be biker
This seems to fit:
Any experiences ?
Hi
Be Biker
I got the derailleur hanger from this company
Funny for my Cube 537113 they indicate the Radon Derailleur Hanger 8651, while the Sram UDH is installed.
Maybe compatible with both, and they installed another one due to the 2021/2022 stock shortages?
Your list can be very useful for the bearings also.
Thank you. Having also a Cube 140 SteHy I started looking for a spare part when reading your post and got frustrated like you as even our German shops are not providing good guidance for looking up.
The table was found as linked pdf via gooogle but unfortunately there is no source info. Nevertheless it looks proper.
Those are Cube numbers of the set, which contains bearings, spacers, bolts.
Didn't find any further dimensions info, but at those prices I think just ordering the sets.
Yes, ordered the Sram UDH I showed a bit higher on this page.
You get a new port and cover as a waranty at your dealer. Much improved version.
Do you have some more details what has been modified vs. the „old“ version:
I always was a bit underwhelmed by the split pin in the Deore BR-M6120 MT520 brake caliper.
The Deore XT brakes, and even the Tektro brakes from my Decathlon Rockrider have a bolt with a clip on it.
Then stumbled upon a tread about the conversion on this forum:
On the forum there was some confusion about the thread size, it's definitely M4
Scientific aligning, angle correction and positioning
Bolt and clip in place, ready to go !
