temon10
only M510 FC 2.0 can change power level via BESST ProCan we change power level via BESST?
Not true, now also new M600 and also M510 FC1.0only M510 FC 2.0 can change power level via BESST Pro
so u change parameter of m600 46.2 version with your blackbox or also can change with besst pro?By power level I mean Current Limit Percentage. Sorry. It is almost the same.
Here is M600:
OK we speak of the same thing. For my part i can only modified seeting of the M510, i can't for my M600.By power level I mean Current Limit Percentage. Sorry. It is almost the same.
Here is M600:
it's you seeting of the M600 ? impossible to apply that on my M510 ?
i have an question about about these current limits. Does somebody know exactely at wich current limi coresponding the 100% of each level ? In use, with original seeting (all at 100%), The max power level increased when you increase the level. I have tried 80% at level 1 and in fact that reduce a lot the power (too many). That whould mean that the 100% of the level1, is in fact already an reducion of the max power, of how many percent ?
sorry for my bad english (i"m also not more clear in my language sometime )Sorry mate, been reading it 3 times, but dont understene to your questions. )
100% current on pass 1 can give you full power on pass 1.
With FC2.0 controller, where you have also support level percentage ( something like sensitivity to your pedalling, or how much torque should add motor to your legs torque. Can be set 0 to 500%) setting, it could work also with rediculously high current levels even on pass 1.
Reality - when it was on default 50% current on pass 1 - I have again did not even pushing into peddals and was going fast as hell. I am suspecting the torque sensor is not so sensitive.
Just try it on 46.2 firmware and it can be tuned with Besst pro. thanks broHello Temon
Yes, BB3 is sending same configuration packets, but without password needed. You can set also in Besst Pro as you can see from my pictures. I just noticed this on my BB3 device, when I was testing it on different motors.
And this M600 motor I bought like 4 months ago. I just let it stay in a box as I thougt it is just normal M600 with older firmware.
Finally possible to change max power on M600. And I guess next version of M600 will have controller from M510 FC2.0 - so even more setup parameters.
sorry i got new controller with 46.2 firmware from factory. old controller is dead.good evening could someone please upload version 46.2 here
Same here, have it only in a controller. Sorrygood evening could someone please upload version 46.2 here
Some source said that before M510 FC 2.0 the controller made by third parties factory and have lot problem. So weird that controller have to be the most quality control.Crazy Bafang. With firmware 46.3 or 46.4 power settings are failing in BESST Pro - and not possible to read.
Have 46.4 48V if somebody wants.
Dont think I have rights to upliad to github.Can you upload to Github
Thx
Interesting, where did u get this info? Could be they have disabled now power adjustments in new m600 controller just because of issues you writing.Some source said that before M510 FC 2.0 the controller made by third parties factory and have lot problem. So weird that controller have to be the most quality control.
Thx, i will contact themBafang M600 M500 M510 G521 G520 mid motor speed sensor kit-GreenBikeKit BBS, ebike batteries, Bafang M620, Bafang M600, Bafang M500, Bafang M510, KT controller with display-GreenBikeKit.com
Bafang M600 M500 G521 G520 mid motor speed sensor kit for replacement.www.greenbikekit.com
This one is based in US I think but shipping faster than AliExpress
remember only controller with 46.2 firmware can set parameter with besst pro. if u put m600 controller to m500 motor i think u have to change 1 cable connector.It's great news that with the new controller for the M600 you can program the performance using Beest pro.
I have an M500 motor, so if I swap the controller from the M600 in it, can I program the power in the M500?
Is my assumption correct?
Assuming, of course, that I reverse the power wires when changing the M600 controller to the M500 motor.
