I beg to disagree, my M600 motor almost totally disengages with no power ( that’s what the one clutch on the outer chainring bearings purpose is ) and I would just suspect it’s the fact you are having to pedal really hard to maintain any sort of comparable speed that you are blaming the motor.
Now on the other hand my mates Bosch Gen 4 will almost lock the motor into having to turn over the stator which should not happen, it’s been back to the dealer a couple of times but he’s being told it’s normal, mmmm.
No need to "beg'' to disagree.
It's just off topic for this thread.
The main question was related to Bafang motors and how well the CEF50--M820 specifically, can be ridden with no juice or w/o the battery in order to hit the bike park. So fundamentally, where is the drag on this motor likely compared to the other mid-powered motors? Especially related to the Fauza60 that is currently on Pivot Shuttle SL and Transition Relay (to be released soon). We were both very interested in the forthcoming Relay contrasts. And I just day demo'd the Shuttle SL recently (which I liked
). Prohibitive cost made me consider this build instead.
So, there is a little drag on the mid-powered motors overall but just some.... fortunately
. And much less than most full-powered rigs.
Personally, I really enjoyed the TQ50. That would be the motor most I would want to ride like an analogue bike. Probably, the Fazua60 second. From early reports from reputable YT reviewers, third would the RS/EonDrive.
Given the projected M820's beefy torque, and high PAS (which is what I want for 8-10 lbs less
) and coming from a full-powered motor, that has very high "unpowered" drag, I'm hoping that it will be far closer to it's lower powered sibling on the drag/pedaling friction rating.
Do you have any feedback on how the well the M820 motor disengages with no power directly compared to the RS, Fazua60, and or TQ50, and in particular to the EonDrive aka (M820--Posh)
For me personally, even while I plan on using the big 720 Wh battery on the CEF50 build, I'll want to DIY a little range extender or two if I can manage it. I hope NOT to go powerless if avoidable. But it would sure be nice to know I could reasonably pedal back to my vehicle with a very low drag motor, rather the have an "anchor" attached (M600
) to my effort that I've had to endure on the past. It all happened after taking a wrong turn, at night, with my riding lights fading, and swearing that this little climb back to my trailhead was blue-moderate, not chunky-black when I rode it on my analog bike the season prior...yikes.
And I was using my backpack spare smaller 450 Wh to make it home.
Fortunately, I made it back with maximal effort with the erie feeling that the phantom mt. lion "stalking" me in very dim light was "close".
The mental panic was great motivation to churn those merciless, high drag cranks to get to "safety" and to avoid future similar pedaling dilemmas.
The natural consequence was to raise my "range anxiety" awareness, which was already high as a heavier Clyde-rider.
I'm using the CEF50 build for more fitness attainment with agility gain and some stealth, so I might not range well...but knowing the 820-Beastie 75/95NM tune will be low drag would be an awesome benefit for money too!
Thoughts on the potential M820 motor drag? Or direct EonDrive comparison?
