- Thread starter
- #781
By the way, I should add, that I know TQ are looking at the forum / this thread, and gathering all feedback that people are leaving, and taking it all on board
Hi TQ
Hi TQ
Agree. But the range is similar across 3-4 rides, I just dug those out as they were the ones I found in my strava.Although I have no doubts about Rob's testing in relation to meters climbed compared to the Fazua, to be fair, they were completely different rides.
Nice - this is a really good thing.By the way, I should add, that I know TQ are looking at the forum / this thread, and gathering all feedback that people are leaving, and taking it all on board
Hi TQ![]()
![PXL_20221029_211920793[1].jpg PXL_20221029_211920793[1].jpg](https://www.emtbforums.com/data/attachments/100/100394-f2b9b27a630ab99917f4dbf441e260f9.jpg?hash=8rmyemMKuZ)
335- Stock everything, low MinoPlease check you BB heights?
It seems we have an "out-of-spec" batch of frames doing the rounds here down south, maybe early production runs, with Trek subsequently changing a seatstay mould? I believe all the sizes have the same rear triangles.
The quoted geo-chart BB height is 342mm in LOW, or 349mm in HIGH. My bike, and 6 different stock bikes on the shop floor that I measured (in all different frame sizes) have a BB height of ± 330mm in LOW (150mm, 29 FR &RR). Thats is 12mm below the GEO chart of 342mm.
The shocks are all 205mm eye-to-eye and the chainstays are ±438mm, so it leaves me to believe the seatstay section (connected to the flipchip) is out-of spec (too short), which drops the BB 12mm.
If you mullet the Fuelexe you drop the BB by 12mm, so our stock 29er front and rear bikes have geo's of mulleted bikes
And don't give me "sagging under bike's weight", shocks and tyres are all pumped high pressure.![]()
The average speed of the tq ride is 50% faster than the fazua ride, that would drain the battery on the tq quicker for every meter of height gained,wouldn't it
Although I have no doubts about Rob's testing in relation to meters climbed compared to the Fazua, to be fair, they were completely different rides. A real comparison would be the same climb back to back with the two bike systems. As a third comparison, below is my ride from yesterday on my exe. There was a lot of flat bitumen on this ride hence the decent average speed but I didn't need to work particularly hard (as seen by my heart rate) to achieve close to 60km and 674 metres of elevation. Again a completely different type of ride (80% paved, 20% dirt)
Looking at the efficiency specs of both motors, the TQ is rated at greater then 90% and the Ride 60 at approx 80%. based on this the TQ is rated at 324Whr to crank and the Ride 60 360 Whr to the crank. This gives the Ride 60 a 10% advantage.
I think bottom line, no one should be disappointed with either one of these systems. No doubt we are in a golden age of ebikes.
Extractor- The usually have some Loctite on them to keep from rattling out. Don't really need it but its handy when you have to pull the crank arm without a special tool.I lost this ring last weekend. Anybody knows what kind of ring this is and how to lock it?
Will call the shop too, but they are closed on Monday......
I only really ride in Turbo mode on light weight bikes, personal preference, but I like making boring bits / hills as fast as possible.
I guess that is the thing with testing range, we all have different experiences. Either way, my EXe having capabilities of 20 miles with 3,000’ elevation is plenty.
Agree for sure. I guess all these range reports are just to be a bit taken cautiously- and just as various data points at best, and should not really be relied upon too much as there are far too many variables.I'm going to be a broken record here, sorry!
Each motor is going to have a wattage/assist level where it's most efficient. My hunch is that, in order to create the most natural feel (and also because it likely has fewest moving parts) the TQ may be optimized for efficiency Eco mode. As a consequence, it could be the system loses efficiency at higher wattages. Makes sense, as it may be using wattage to compensate for torque.
Rob's test was great, and I appreciate it.-But it may not tell the whole story. As it stands, seems like if you're purely after max range, the Fazua is indeed more efficient. But could the HPR be equally/more efficient at lower wattages? We can't say... yet.
We have a local trail that has a paved climb, about 450m vert in 3km. On my previous bike (Norco Sight VLT/Shimano E8000) I found that trail mode consistently used LESS battery than eco mode!
I got 720m of climbing over 16 miles on my first ride yesterday,which tallies with robs figures.Agree for sure. I guess all these range reports are just to be a bit taken cautiously- and just as various data points at best, and should not really be relied upon too much as there are far too many variables.
Either way, interesting to learn what others are experiencing
Even EV cars range tests are ridiculously variable, e-bikes arguably are even more variables.
Given your numbers, you were hoping for 77% of the height with 58% of the battery capacity when you actually got 55% of the height (your rough numbers from memory for the 1300m) with 58% of the battery? Unscientific as it is, sounds about right to me for the same kinds of rides.I got 720m of climbing over 16 miles on my first ride yesterday,which tallies with robs figures.
I have to say I am a bit disappointed with that, but I had tweaked the modes to offer more power/assistance than default, and I'm still learning how to get the best out of it.
I usually ride my full fat Bosch gen 4 (with 625wh battery) in tour+ mode, and that will typically give me ~1300m of climb over 30 miles ,of a similar ride.
I've since lowered the power/assist in the first two modes,so will see how it goes.
I was hoping for around 1000m of climbing without having to resort to the lowest power mode too much
I was hoping for around 1000m of climbing without having to resort to the lowest power mode too much.
Could you post a screenshot of your motor settings?I got 1100m on the first ride over 32km, all singletrack climbing, I weigh 84kg.
I did the first 80% in Eco, then realized I wasn't going to kill the battery so put it in boost for the remainder and finished with 12%
I think it's wattage, not assist level, that drains the battery. In the app, If you lower set the wattage for trail and boost, but increase the assist, the app shows similar ranges for all 3 modes. Thus, "I think" using lower wattage/higher assist is the way to get max vert range.
Yes,but I put more of my own effort in on the fuel than I would have done on the Bosch bike, hence thought I should have got more range from it.Given your numbers, you were hoping for 77% of the height with 58% of the battery capacity when you actually got 55% of the height (your rough numbers from memory for the 1300m) with 58% of the battery? Unscientific as it is, sounds about right to me for the same kinds of rides.
That's fair. I saw a YT vid the other day of a guy who was going to isolate rider effort with the fancy input torque measuring pedals. I haven't seen him post the full test yet though.Yes,but I put more of my own effort in on the fuel than I would have done on the Bosch bike, hence thought I should have got more range from it.
I think both the Assist Level and Max Wattage Level affect how fast the battery drains. If you set the Assistance Level to 100%, the battery will drain twice as fast as it would if you set it to 50%. That is guaranteed, all the time. At 100%, whenever you are pedalling, it is working twice as hard as it is when set to 50%. Max Watts only affects battery drain when you are pedalling harder than normal.I got 1100m on the first ride over 32km, all singletrack climbing, I weigh 84kg.
If you input 200W, and the bike assist is set to 100% and the Max Watts is set to 100W, the bike will only assist the same 100W.
Try lower assist and higher Watts settings. You might like it.
Now I get it, sorry. You do a lot of climbing and I wasn't taking that into consideration! You are a wild man for doing that much climbing with only 100W max assist! If I understand correctly, if it gets a little too steep you click into Trail mode for a little more assist. I think it is possible that you could find a setting, like 85% and 125W where you would get the best of ECO and TRAIL in ECO mode.Agreed here, and with your descriptions of what the settings do.
Both these things can't be true simultaneously. If your max watts is 100w, once the motor is putting that out, any additional power comes from the rider, not at the expense of the battery. Which is why I propose the low wattage settings to get max vert. There's no magic here, it's sort of neutering the bike so you don't get carried away in boost mode and kill the battery.
In my case, I tried creating 3 modes that were all somewhere between stock ECO and TRAIL modes, 100-150w, with varying levels of assist. I'll post a screengrab later.
I'll try it, but I don't expect to get 3500' /1100m+ with higher wattages. What do you think?
I'm definitely enjoying using the app to see what's possible. Make all 3 modes identical but with one variable, etc.
Hi Rob, Thanks for all the youTube videos and the website.Agree for sure. I guess all these range reports are just to be a bit taken cautiously- and just as various data points at best, and should not really be relied upon too much as there are far too many variables.
@Rob Rides EMTBView attachment 100361 View attachment 100362
Here’s the Strava data. The TQ was with original tyres too.
These are the sort of "max vert, all singletrack" settings I've been going off about. All three modes somewhere between stock Eco and Trail.Could you post a screenshot of your motor settings?
Could also post it hereAll good! That's what I like about this bike, being light and natural feeling, it's a good climber even at lower assist levels, and still rideable with a dead battery. Of course for shorter rides I like full boost too.
ATTN: TQ - Feature Request
Would be awesome for the app to have a few "preset banks" where we could save mode settings optimized for different ride types. Max Distance (level 1/2/3), Afterwork Rip (level 1/2/3), Technical Climbing (level 1/2/3) etc.
Mine is 330mm in Low, Size medium. Canada.Please check your BB heights, and share!
It seems we have an "out-of-spec" batch of frames doing the rounds, maybe early production runs, with Trek subsequently changing a seatstay mould? I believe all the sizes have the same rear triangles.
The quoted Trek Fuel Exe geo-chart shows a BB height of 342mm in LOW, or 349mm in HIGH. My bike, and 6 different stock bikes on the shop floor that I measured (in all different frame sizes) have a BB height of ± 330mm in LOW (150mm, 29 FR &RR) or 337mm in HIGH. Thats is 12mm below the GEO chart of 342mm LOW, 349mm HIGH.
The shocks are all 205mm eye-to-eye and the chainstays are ±438mm, so it leaves me to believe we have a batch of seatstays (connected to the flipchip) is out-of spec (too short), which drops the BB a lot (12mm in this case).
So really curious to see what is doing the rounds in other parts of the world? Please share!
The bikes were held-up by the saddle on a bike stand, with rear wheels barely touching, so no sagging![]()
Thanks! When did you take delivery?I’m closer to 332mm than 342mm in LOW.
