The blue parts are for the E10! The weld bracket / fixation part is not needed.
For the Dengfu e10 it should be these.
I ordered a M510 yesterday via Chili Shen / Alibaba. ETA by 20th of March.I received a message that the M510 engine has entered mass production and will be available for sale in Europe in April / May
Yes, I got the news about the m510 engine from Tosabike.Tosa bikes is also testing one, i have asked them, while purchasing a second battery from them.
Most interesting would be the derating behavior/ attenuation of the battery SOC below 30%. This was a pain in the ass with 10A firmware and drastically improved with Kyokushin 13A firmware. I hope they considered this within M510 development…Tosa bikes is also testing one, i have asked them, while purchasing a second battery from them.
Thanks for the input! Ficorama contacted Tosa, as You mentioned You need to send the Motor and Display to get the firmware flashed. I‘m also Member of the FB group You mentioned. Would be great to convince the guys to share the file…there is a facebook group for m500 m510 and 600 the owner of tosa posts there from time to time.Probably we should ask
To be honest i am pretty happy with my firmware which is already from spring last year.Right now i am building for a friend a bike with stock motor from dengfu.Interested to see the difference.But yea tosa can reprogram motors amd they are testing all the time.Unfortunatelly they do not post their firmwares, man need to send the motor.
It is their "added value", i doubt they share it freeThanks for the input! Ficorama contacted Tosa, as You mentioned You need to send the Motor and Display to get the firmware flashed. I‘m also Member of the FB group You mentioned. Would be great to convince the guys to share the file…
the battery depends on the frame you are using.The m510 motor will be compatible with btf03 and btf04 batteries just like the m500. In the bafang catalog the m510 comes out with the btf012 battery and the battery measurements are different
It will work for now! Much appreciated. Where did you find this? Also do we know if the 510 is the same profile for mounting?Not sure if this is any better.
You just need to find a belt drive chainwheel for 104 BCD. And You need a chainstay that can be splitted, because the belt can not.Oh, I forgot add to my last message, has anyone successfully converted an bafang M500 or similar to a belt drive? I found Using a Gates Belt…a BBS02 mid drive gets UNCHAINED! but I've not yet found any good info on any of the M series being converted to belt drive.
Thanks everyone! Yeah, I am aware that I need a splitable chainstay, I'm having a custom frame built up for this. I found this intergration guide from Gates later in my search which shows compatibility across several bafang motor and hub pairs: https://www.gatescarbondrive.com/~/media/files/gcd/ebike-manuals/gates-cd-ebike-manual-en.pdf?la=enYou just need to find a belt drive chainwheel for 104 BCD. And You need a chainstay that can be splitted, because the belt can not.
It is this shop Changzhou Victory Machinery Co., Ltd. - Electric Bike, Electric BicycleThanks everyone! Yeah, I am aware that I need a splitable chainstay, I'm having a custom frame built up for this. I found this intergration guide from Gates later in my search which shows compatibility across several bafang motor and hub pairs: https://www.gatescarbondrive.com/~/media/files/gcd/ebike-manuals/gates-cd-ebike-manual-en.pdf?la=en
@thaeber would you mind posting a link to which alibaba store you purchased your M510 from?
Can't wait for some reviews of this, the weight loss is an attractive feature and if it's as good as the m600 at lower power, it's a no brainer for me as I never usually exceed level 2 on the m600.It is this shop Changzhou Victory Machinery Co., Ltd. - Electric Bike, Electric Bicycle
Chili Shen is the person you can talk to.
They're certainly charging a premium for the M510, I was concerned about the "repair" I'd done to my M600 and it's potential longevity in the wet UK conditions, so I've ordered a M510 from Alibaba last week and mine has apparently shipped. Not sure how long it will take to get here, but I'll try and post firmware versions etc. when I get my CANBUS setup running (or get a BESST tool)![]()
SINGYIU BaFang M510/G522 Mittelmotor Drehmoment Mittelmotor CAN-Protokoll Elektrofahrrad Nachrüstung 36V43V48V250W - AliExpress 18
Smarter Shopping, Better Living! Aliexpress.comfr.aliexpress.com
The M510 engine is compatible with most of the products in the Bafang portfolio, such as the Intube battery, the DP E180/181 displays with a clean LED HMI, the optional enhanced color version DP C242 HMI,
((((((the hidden speed sensor with two magnetic fixing solutions))))))
and the next new Bafang application”.
