Reign E+ 2022
Mine has arrived from Canada (E+0) so now all I have to do is locate a battery. I have contacted several Dealerships non of which have any in stock (no surprise there). So if anyone has a spare kicking about please get in touch (UK based). In the meantime I plan on doing a lot of pushing!
hi guys, I'm arguing with the Fox Factory 38 of E + 0 I can't find a good setup, my hands and arms hurt, it's hard, Do you have any advice on a good set-up? weight 90kg with backpack and clothing
I hope it doesn't have any problems, you don't even hear the clicks of the low speed compression when turning the knob
I asked this earlier but haven’t had a reply yet. I’ve found that opening both high and low compression up really helped. Also adding a bit more air than recommended to get the sag right. It seems to keep you higher in the stroke. Also have the low speed rebound quite quick for the smaller breaking bumps and roots etc but the high speed a bit slower for the bigger hits.
Because of the heavier weight of the bike it definitely needs different settings than the recommended ones on the fox site.
I’m running 98 psi with both hsc and lsc nearly fully open. One or two clicks definitely make a difference (I can’t feel the clicks on the lsc but apparently this is normal. If you really concentrate you can just feel something)
There’s a good video on YouTube by one of the Fox riders called Jeff Kendal-Weed.
So the first proper ride out today around peaslake, Surrey hills area. It was very very wet. I rode probably 80% of the ride one up from eco which I found was plenty. The rest I rode in either auto or full power. I would say ignore the estimated range when using the app.
Not sure if US will have 750 batteries available, only reign e+2/3 available here. No +1 or +0. Good info all, thanks!
Some of them need some additional loving, this might be your problem :
    Join 43,245
