• Warning!!
    UK Pedelec Law
    Worldwide Laws
STUnlocker (ex Shimano STEPS Unlocker) Android & Windows App for derestriction/market change and etc
No you dont need additional files there. I have only those two and it is working. Just be sure you have etube 5.0.2 or older.
You are right. 5.0.3 App doesn't offer an update... It's sad
ETube Project 5.0.3 for Windows still works
This folder MUST have many other files. It looks like you delete all files before or you created that folder by yourself. Try to use recommended file browsing Apps and copy FW files using a phone
Yes I tried first to keep all files there and it didn't work as well.
Thanks. I was able to download now just waiting for my friend to stop by as he has ios. Thanks.
You are more likely to have success with Android than IOS. You can side load older version of Android apps. IOS apps are signed and you will not be able to load older version.
It's uploaded for iOS, but it takes 1-2 days to approve the new version by Apple...
p.s. The new version (.108) was uploaded to Google Play also, may be it will work for you...
@vadII
iOS version working fine, max W changed and it was stored correctly and affected the output. Still some vibrations on ep8-rs when setting to >350W and battery <50% but I think this is a battery or motor limitation.
thanks!
100 Nm out of an EP8???
Perhaps I've overlooked this in the past, or maybe it's a new option. Just minutes ago I upgraded my firmware to 4.1.8. I also upgraded STUnlocker to whatever today's version is. I was just clicking around though the options, and discovered an option to bump up the torque to 100Nm. It's on the same screen where you can kick up the power from 500w to 600w. Is this a new option? Has anyone done it?
Bonjour,
Je n'arrive pas a configurer mon EP8 avec l'application ST UNLACKER, même avec la licence prenum. je ne sais pas quel fichier .dat sont a garder ou pas lors de la connexion a l'aide de iFunbox. y a t il un personne qui aurait directement les fichiers a réinjecter dans l'application via iFunbox. par avance merci. sous iphone XR
You could do something similar with the e8000 motors in the older versions of the software, so I don't think any of this is new, though I don't remember the torque figure going that high on the e8000.
Someone did up their e8000 to the max wattage a long long time ago and burnt the motor out - co-incidence or not I don't know, but certainly something you do entirely at your own risk.
I did play around with it on an e8000 with the figures bumped up 10% from normal. The motor did seem very slightly more powerful, but considerably less smooth in it's power delivery. It was as if the algorithm didn't adapt for the larger power envelope and it all just felt a bit "rough" and snappy - wasn't an overly nice riding experience.
From what I remember, in back to back tests it took 1 second off a 2 minute climb. I suspect the software was already configured for the optimum performance from the hardware and increased power allowance didn't directly correlate to real world performance gains.
I tried to Programm it. Up to 99nm it saves the setting. If you try 100nm it switches Back to 85.
And even if you set to lets say 95nm you can't set the value in the assist settings, only up to 85 nm. So i think its a Glitch??
And the max Motor Power can't be set above 500w on my Ep8 with 4.1.8? I thought thats not an option to set the max power over 500 w for the Ep8?
Only can do that on my e8000 with 4.3.2
Thanks, guys. I don't think I'll goof with it at this point. I like to push the envelope, but I ride so rarely in Boost, that it seems like a poor utilization of my time to squeeze another 14-15Nm out of the motor.
Hi everyone,
New here, a proud rise owner M20. What is the best (safest) way to remove the speed limit to US 20mph? Not too fussed about Nm as 60 is plenty and hardly ride above eco anyways.
I've never upgraded the FM since getting it so I know there is a new update available. Can I used android and STunlocker ?
What's the process and any impact on performance/range/battery?
Many thanks
I have the app with license and set my E6100 to USA regional 32km/h. But now I want to get a little bit more speed like 35km/h with the right speed showing up in the display. Does anybody know if this is possible?
Did u do it via Bluetooth or PCIE? I have the ep8RS
set US + 1300 circumference
Does the license only worth for 1 bike at a time? Or do I have to buy a new one every time I get a new bike? Cause it doesn't work with my new bike for some reason, downgrade to 4.5, e7000 but the circumference can't be changed or the country unlike my previous bike
This is what Shimano can see, even if all settings are returned to original ... in case you need to use your warranty.
I see the same messages when settings of my bike is not default. With default settings I don't have any messages.
Could you send me a screenshot from STUnlocker with the bike's info and regulation settings (if it's EP8) and I'll tell you what is not changed to default/factory.
OK ... apologies, I reset also the assist settings, and the warning has gone. I'll just delete the post, thought it was a new feature in etube professional.
excuse my ignorance, been sifting through this thread and can't find the answer...
1 - my EP800 firmware is currently on 4.1.1
2- I have the $1 version of STunlocker (my app does not give me any option to upgrade in the menu, unless my eyes are really shit, I must obviously be connected to the bike then for the option to appear)
3 - What will happen if my fimrware updates after the region change? Will eTube change back to EU or stay on US? I will most likely lose my settings?
1. Ok
2. You have to connect the bike first to get the Premium licence
3. Nothing. Moreover, for EP8 motor you have to upgrade firmware to the latest version after derestriction.
No.
No.
If doing it over Bluetooth you will need to downgrade the firmware to 4.0.1 I think. The rest is straight forward (as above)
Just make sure to put the phone in airplane mode as it can cause disruption during upgrading/updating.
I also have Rise H10 and iOS 15.3.1
iOS version1.14.82 of ST Unlocker. Will that work to downgrade the firmware from 4.1.6 to where it needs to be for unlocking?
I was just following this post and Im trying to avoid any issues before I start.
It's not possible to downgrade the firmware using iPhone with the latest ETube App installed on it. So you can't derestrict the bike via Bluetooth. Get an android phone for downgrading or get Shimano PCE interface for derestriction without downgrading (Windows PC required)
Is this something I can use a MacBook with along with Parallels? (Winders emulator for Mac)
And is there a specific Shimano cable to use? I think there are a few...the Di2?
Yes
PCE-02, PCE-1.
But I would recommend you to find an Android phone for downgrading and then derestrict your bike using iPhone
    673K
