The Official BLEvo Thread
Status
Not open for further replies.
Am I doing something wrong. I’ve just downloaded BLEvo app iOS and it finds the bike and connects but just hangs when trying to readsthe bikes parameters.
Sorry but there is a bug. The new version is already under review by Apple.. I hope it will be downloadable tomorrow..
Sorry again for the bug
Thanks for clarifying this.
Will the update be available via AppStore?
Hi Guys,
I have a 2019 levo TCU 2.025
I can change my wheel size to between 2100 - 2400
At 2400 this increases my max speed to just over 26.2kph
This is not a lot but my gps confirms the higher speed.
The maximum possible wheel size is 2400
@PaoloBLEvo
Can you allow for a larger wheel size to be selected?
I appreciate some other data will not be correct but it may givea temporary solution to the higher speed.
Am I doing something wrong. I’ve just downloaded BLEvo app iOS and it finds the bike and connects but just hangs when trying to read the bikes parameters.
Running version 10.22.3
Same for me with latest FW in Levo 2018. Probably something wrong with latest upgrade.
Recently started useing Blevo.
I like it so far
Excuse my ignorance but what is CM and what are the pros and cons of customizing CM settings in the various assist modes ?
Apologies if this has been covered before.
I started trawling the thread for answers but i gave up after several pages
I'm running battery firmware 2.22.3 on my 2108 Levo, and the version of BLEvo iOS downloaded last week works fine. Love the App and tuning options!
Paolo - a couple of suggestions for changing the Display options.
1. Can you make it an option to get rid of the speed and cadence meters and just show the numerical values as large block numbers? The values are difficult to read with the "dial".
2. Can you make it an option to not use color backgrounds on the Display? The color coding for ECO/TRAIL/TRUBO is helpful, but the added color in other fields makes the numbers difficult to read.
Ciao! and Thank you.
Hi Guys,
@PaoloBLEvo
Sorry but in BLEvo you must change the speed not the wheel size. I think 26kph is the "normal" limit.
Could you send the screenshot of the configuration?
I like it so far
Which firmware version you have?
Are you talking about iOS version?
Sorry but the answer is only the same as written here
(Unlock speed) Is it possible to change the wheel size on the Levo 2019?
TCU version 2.019 or V1.7.0 = wheel size and speed limit are changeable
TCU version 2.025 = wheel size and speed limit are NOT changeable.
For the TCU version 2.025 I'm analysing other solutions
I found I was reaching the 25kmh limit incredibly quickly so I increased it a bit (mainly to make the uphill ride to the trails I ride less tiring). Really pleased with the result. Still need to get a lot more riding in to fine tune the settings and may well reduce the speed limit a bit but it’s really good to have options.
I was only able to change my wheel size down to 3100mm from 3300 on the 2019 Levo. How do I adjust it to 800 so that the limiter is off?
Hi Guys,
@PaoloBLEvo
I might be thinking this wrong...But, if you increase your wheel size in BLEvo, then surely that would reduce your actual speed if you’re running smaller wheels than you set in the app...? the bigger wheel would rotate slower at a higher speed than a small wheel!
Just a thought!
Hi Paolo, my BLEvo app was working fine yesterday...but I updated it this morning in iTunes and now it hangs when I try to go to Bike Setup? It just says...
”Please wait.. Reading all parameters”
But doesn’t move on from that screen. It finds mi bike ok, and says it’s connected, sees the battery software but that’s it ? I wish I’d not updated now as it was perfect yesterday ☹️
Hi Dwazzer, which version of BLEvo did you install this morning. Possibly you got the "yesterdays" version 3.1.1 which had exactly this problem. 3.1.2 came in later this morning.
please doublecheck if you got another update in you queue.
i had the problem you described yesterday but this was fixed with 3.1.2
Forget that Paolo, I deleted BLEvo off my phone and reinstalled it again from iTunes! It all seems to be working fine again now ?
Thanks Tom, I only updated it this morning (about 10:30am)...but a delete and re-install has fixed it ?
About wheel size and speed limit I think there is a little confusion about the parameters in BLEvo.
In BLEvo there are 2 parameters:
- Wheel Size (mm)
- Km/h (Speed limit)
In Mission Control there is only 1 parameter
- Wheel Size (mm)
In BLEvo MUST be configured the REAL wheel size because BLEvo need this parameter to calculate the right speed and distance done.
In Mission Control will be shown the FAKE wheel size in function of the Speed limit configured in BLEvo.
I hope with this table you can understand better.
Please, I repeat again. In BLEvo you MUST enter the real wheel size.
Thanks.
Paolo.
Have you stopped the Mission control app?
I like it so far
Just noticed its called CM in the manual but PP on screen
@PaoloBLEvo can you explain what this is please ?
CM is available on firmware x.22 and x.18.
PP is available on firmware x.23 and x.3.
CM means motor current and PP means Peak Power. There are many post and documentation that talk about CM releated to the firmware version.
For PP I suggest to keep always 100% in each mode.
So can you hack a 2019 specialised expert carbon levo? I do t want to pay 8.99 for it not to work?
Status
    Join 43,176
