The Official BLEvo Thread
Status
Not open for further replies.
Wow, 151 pages.... I'm interested in Blevo.I like the mission control very much. What are the advantages of bleib compared with MC. I use an iPhone and have a Levo 2018 and a Creo 2021.
Hello over here! ;)
First of all thanks to this great forum for all the valuable input I already got from here.
And of course *very* special thanks to Paolo for this wonderful piece of software. Really great stuff! (I esp. love Smart HR ;) ).
Nevertheless, I have a problem that is kind of annoying (and which is the main reason why I registered now).
Would be great if someone can perhaps give me a hint to solve it ...
So, nearly every time I start BLEvo's Bike monitor (on first try), I get the message:
"DEM/HGT files not found for this GPS location (...) The ride cannot start. File not found: N49E009.hgt"
But: This file exists. Among others. In "Main Storage/BLEvo/DEM".
During the first few weeks I then really restarted BLEvo, and on second start, the message did not appear again.
Meanwhile I ignore it, cause I got the impression, that it makes no difference ... even displaying the altitude graph of the current track seems to work pretty fine.
But uncertainty of course remains. And apart from that the message is a bit annoying, disturbing - and unsettling.
So, perhaps someone can tell me, why this (false) message appears, how to get around it, i. e. satisfy BLEvo ...?
Ths a lot in advance!
Thanks...
For the issue, which version are you using?
BLevo IOS and Turbo Levo 2021, sometimes "motor" remains red, not connecting. Everything else works well.
What could cause this?
Il the "motor" is red, means that the data from the motor is not received, so you will not see the power of the motor..
Please try to clean the connector between the battery and the motor..
There are a lot of differences from Mission Control and BLEvo.. first of all is the Smart Power.. automatic assistance percentage in function of the legs power... it is more or less an automatic gear system...
I sometimes found that I needed to turn the pedals for the motor to show green 👍🏻
Yesterday I bought Blevo and tried it on my Creo. Great - just a different bike with extended Range!
If the user interface and the description to be found in the internet would be better I would have bought it much earlier.
I have some questions which were not answered in the manual: for example: What means "ACC"?
Gents a quick question , I've just bought a Levo Turbo 2021 , is this easy enough to set up for someone who isn't very I.T. savvy ?
Do i not bother with the Mission Control app or just add BLEvo to my iphone ?
Is the App £7.99 just so i know i'm downloading the correct one ?
There is not possibly to modify the screen in IOS? I don't need so much data on the screen. Prefer BIG numbers and less data. :geek:
You can adjust the screen with the "config-Button". on the following Screen you can decide what should be displayed. I like to display speed and cadenza with big rings.
Is there any way to integrate / combine Komoot and Blevo. I like to plan, navigate and document routes with Komoot. My workaround is to let kompost in the background guiding me via voice commands and let Blevo displayed all the time to see cadenz and heart rate etc. Are there better workarounds?
No you can't. On IOS you can't delete unnecessary boxes, they can just be left blank.
So they take up unnecessary space on the screen.
I am looking for a replacement for my Blackview BV6000 which I used for cycling with my Kenevo. The Blackview BV6000 has a built in atmospheric pressure sensor. Can anyone tell me what new outdoor Blackview or other outdoor devices have an atmospheric pressure sensor and are recommended for Blevo?
v3.10.0
Ok.. The issue should not be present... Android version?
Yes
@PaoloBLEvo Any idea? Can I be of any help? Perhaps provide debug data ...?
Hi Guys, I'm a long time user of blevo on my levo 2019. I want to buy the gen2 levociraptor for getting higher speeds above the 29km that I now can reach. My dealer has set the wheelsize in mission control to 2000 mm long time ago. Do I have get it reset to 2300mm before using levociraptor with blevo or can I leave it at 2000 mm? Thanx
Thanks a lot..
"ACC" means acceleration...
No sorry... the iOS version has only one display type.. With the Android version you have different display and also the horizontal version..
You can download the GPX from Komoot and use it in BLEvo..
No, you don't need to reset to 2300...
The thread is very long...
I created a new one..
We can continue to discuss here..
Thanks for all your support.
For everyone "Watching" this thread. You'll need to select "Watch" on the new thread to make sure you get updates accordingly.
Hopefully anyone watching the thread will see this and move over. If you're watching and don't see this, you're probably not watching !!!
Status
    668K
