Power tube battery getting stuck
Funkeydunk
381
280
Uk
Hi guys, any ideas on the solution in getting a Bosch power tube out of a bike, mine has become stuck and it looks like a warranty job. The battery does come out if you apply brute force. Of course this shouldn’t happen at all. Thoughts?
Mteam
1,794
1,732
gone
The lock barrel can get a bit sticky, and there is a spring loaded sliding mechanism where the battery clips into place that can get sticky, a bit of silicone lube on this can help things along.
Funkeydunk
381
280
Uk
We covered it in lube and it’s still sticks, to the point where you break you finger nails trying to get it out
The EMF
🔱 Aquaman 🔱
1,156
2,019
South East Northumberland
Try this hack……might give you a bit more to hang on too when removing the battery
Funkeydunk
381
280
Uk
Alas, my battery attaches differently to that picture.
RickDale
Queeny, Bradford
Just had the same issue on my new Hai bike which is only 6 months old. This has a powertube 500w battery with boshe performace drive. Could not get the battery out initially, tried wiggling the key and battery like suggested. Felt like the battery was releasing slightly but would not fully pop out. Got it out eventually by turning the key while standing over the bike & pulling the key upwards towards the seat (not too much pressure). This then popped the battery out. Now I had the battery out I could feel the key barrel was loose, this is held in by 2 bolts which can be tightens with a T15 driver. Assume these bolts had rattled loose while biking. Please find pics attached. When checking the bike over also found the bolts holding the disc's on where loose, I suggest anybody with a Hai bike to check all the nuts and bolts are tight ;)
525K
