Trek Rail upgrades, what have you done?
Took mine for a 21 mile ride today, came home and my 220 rotors and adapter were delivered.
Just finished fitted them. Bedded in the rears, almost bedded in the fronts on a couple runs up and down the street. This will help a ton bombing down the hills. I feel the extra weight and now feel the brakes are matched better.
Trek Rail 7 XL Miami Green/Nautical Navy
I change almost all parts
- Rockshox Zeb select 170mm
- RockShox Super Deluxe Ultimate Coil RCT, 650lbs
- Sram code r brakes, front 220mm and back 200mm rotor disc
- RockShox Reverb AXS 170mm
- SRAM XX1 Eagle AXS and X01 cassette
- Roval traverse wheels
- Kiox offcourse
- Kiox offcourse
Can you put any pic? Thanks
Offcourse
- Kiox offcourse
Damn I thought I was bad, I went with all XTR race face next 31 carbon wheels and XTR 4 piston brakes. But you my friend take the proverbial cake
Think I'm finally done upgrading.....unless I upgrade to a Volt/Raw 9.7 frame, & swap all the parts over. Components are dialed (just need to install 220mm rotor up front).
Upgrades:
2021 Fox Factory 38 Grip2 170mm
2021 Fox Factory DHX2 230x65
Santa Cruz Reserve 30 I9 Wheels
Magura MT7 Brakes w/ 220/203 MDR-P Rotors
Bontrager Pro 35 40mm Stem
Raceface Next R 35 Bars
Crank Brothers Mallet E Pedals
e13 160mm Cranks
Kiox Display
Fizik Tempo Argo Saddle
OneUp V2 210mm Dropper
Wolftooth Fat Paw Grips
Upgrades:
Magura MT7 Brakes w/ 220/200 MDR-P Rotors
e13 160mm Cranks
Kiox Display
I want ot run the 2021 Fox Factory DHX2 230x65 on a large rail frame what do I need to make that happen besides the shock itself?
I ordered new standard hardware from offset bushings and just installed it (I did re-use the black caps from original hardware as silver didn't look as good.). I had no fitment issues. With the spring off i Jumped on the pedals on no resi or seat stay contact on a large Rail 7. Shock Bushings | Trek Rail
can i ask what the part numbers where for offset??
I feel way more stiction at 170, then I did at 160, just IMO. So the off the top isn't as supple as it was at 160.
Ahh that makes sense. I put the Zeb ultimate at 170 on mine and for me the performance far exceeds the stock Yari my Rail 7 came with.
Yeah it just feels so solid and the action is like butter. My thought was run it slightly more into the sag than the 160 and it should be basically the same geometry sitting on the bike, but smoother and slightly more travel.
I’m very pleased with it.
Ok bought a trek rail 2021 9.8XT drove 1000 miles roundtrip to get, brought it home road couple times and did not dig the SLX brakes or XT shifting, I have a 2021 Bulls Copperhead and its has same bosch motor XTR throughout and I wanted trek to be XTR Soooooooooooooo Pulled it all apart in my kitchen Put XTR 4clamper Brakes Xtr shifter Derailleur 10-51 t XTR cassette Got a Reverb stealth dropper BUT decided not to go hydraulic and replaced Bontrager dropper post cable with jagwire and wolftooth trigger and then yanked the pro line 30 ally rims and replaced with raceface next 31's with Vault hubs and Schwable big betty's fr/rear. also xtr 203mm rotors and finally raceface atlas pedals and a raceface next carbon bar with 35mm rise If i can score carbon arms I will. She is done my friends and the copperhead is for sale
Fitted the speed box 3 and took it for a wee spin. Managed 34mph on a flat. Marvellous. Looking at some new faster rolling tyres now. Any recommendations?
Just ordered a 3.0 for my rail 9.8 Already had In my 2021 bulls Copperhead that I just sold, But I couldnt remove it because I was unable To remove the carbon Praxxis Crank arms off the bosch motor So new owner that just bought Bulls got a free speedbox 3.0
I lied...one more upgrade. My NYON display to upgrade my already upgraded Kiox display....lol. Should be arriving tomorrow.
    670K
