walfersama
@walfersama - I've got one suggestion actually and have uploaded a new version of the data field, which might help work out what is happening in your case. If you try it, you may need to be careful to remove the old version from your watch first before installing the new version (I was experiencing some odd things happening when I was testing updates via Garmin Express).
But with the new version:
Whichever of those 2 options occurs would give us some more info
- If it displays "BLE Start" - then it means it is the same Garmin bug that happens with Vivo 4 & Venu (and another watch may still work)
- If it displays "Scan" like before - then it probably means the EM800 display is using a different bluetooth data format
the watch's display shows "ble start", while the shimano display shows the bluetooth-logo constantly.
what i have to add - the 530 seems to naturally support the display. I can connect my edge 530 to the display without needing to install a 3rd party app and it shows battery percentage right away.
