Dengfu E10 - The CHEEB V1.0 - Discussion
Went out front to bring the bins in. And this box was sitting on my door step. No indication that it had been delivered or about to be. Just sitting there. So glad I live in a very quiet street. Nice looking bit of kit. Ordered with the frame on the 22jan. No frame or battery yet. I don't mind the screen or buttons, they feel good to me slight rubber feel. I like it.
for me (france) the battery was inside the motor (M500) parcel
Hi guys, does anyone have information regarding weight of the battery with 800wh? Just received mne and seems like a ton ??. Did not have the time yet to weight it. Maybe someone else did?
I got information regarding my order - motor will be here this week, frame shod be finished in 2 weeks (ordered end of January) and for the battery they don't know exactly when will be on stock :confused: but frame and battery will be shipped together.
with a custom color frame ?
Charging only to 80% or even 90% will significantly extend the life of the battery (number of charge/drain cycles etc.). But obviously you won't get the same range as 100% charged. You can either use a "smart" charger or do it on I timer I guess. Not sure if any BMS have the ability to cut the charge at a lower rate too.
That said if you want maximum range, just charge to 100% and save up to replace the battery when you start losing range.
I check also my order status=ordered mid february. Motor will be shipped within next week, frame+battery within 1 month. default black, no custom colors
Ordered mine beginning of March so estimating based on yours and other people timelines it will make an appearance end of April early May
Guys,
bought a whole bike from Tosa bikes.So far i like the m600, although a bit loud but not intrusive,i will improve on this.Biggest problem is that i have a scratch on the swingarm.Not sure during the transport etc ,Do you thing it is a major one?
Its nothing. If you "land" into rockgarden with bike multiple times, you will find a bunch of those. As colleague said, epoxy/primer, paint&forget. Its from shipping, but make no sense to ask for replacement :)
OK thx guys for the feedback!About the bike i have received the batch with the old motor, but Tosa informed me about this before the purchase.So it is not that loud.I think the bosch gen4 is louder.So now i need to purchase some parts for upgrades and will test it in the mountains soon.But so far i like the motor although 4kg.
Greets
Sava
Looks like the Ali inserts haven't been bonded into the carbon correctly or possibly you have over tightened the bolts in the warm of your garage and then gone out into the cold ? Can you take a photo of the area where the inserts sit in the carbon as if its a clean fracture of the bond and the inserts will fully sit back into the recess, you could just super glue them back in or better still use one of the specialist epoxy glues designed for the purpose
High Performance Structural Adhesives - Easy Composites
Hi.
I got M600 motor last week and for comparison there is my motor Nr. MM G521.500.C11 and on controller CRX10N.500.FC 3.2 (Software version CRX 10NC4818il32 046.7) - if someone would compare those numbers with his M600 motor to check what version is it. I don't know if I got the newest with hardened nylon gear (I'm a bit sceptic about nylon - PEEK is there normally much better).
Frame should be finished this week and I got question if I could take 16Ah battery and not 17,5Ah since this can be delivered quicker (no answer until now how much quicker).
BR
Bogdan
Hi.
BR
Bogdan
I got the same question. I said "no" I'd rather the 17.5 ah battery. I think I have waited this long a few more weeks will not matter.
So finally my framset is painted and will be shipped within today. Looking forward to assemble my new bike :). Does anyone know if a Rock Shox Super Deluxe select + from a Santa Cruz hightower carbon cc with 210 x 55 mm will fit without problems or is it just a model that fits in certain bikes? My ordered shock was a Super Deluxe Ultimat RCT DonAir 210 x 55 mm but they do not know when it will be available. What shock is the better one? Thanks guys
(y)
If it's similar to the one I got on ebay, it's not compatible without changing the damper body for a standard instead of bearing eyelet (this is what I bought wrongly and it's too wide by a long way).
The damper body from the the standard one is swappable, but when it came to replacing it with a standard one, there was a long lead time for the standard damper body, so I bought a deluxe with a standard body as a donor and paid Sprung Suspension in the UK to change it over and service it (same price as standard service).
Hi guys. Question from a new owner. How do you wash/clean the bike after a muddy ride? Specially the area where the motor is. Thanks.
Hei Guys,
how many Nm are you using in order to mount the motor to the frame?I want to use 30t narrow wide chainring.Do you think this is possible?|
    Join 43,186
