JMD
Bit pricey for a experiment, I'll have a try if one appears on eBay a bit cheaper
You can limit travel fair more easily than a full rebuild - just do what Ohlins/PUSH/Ext do & put a plastic travel spacer under the bump stop.
You can buy nylon washers with the ride ID/OD on eBay/Amazon in various thicknesses - just pick what you want to run whatever travel you like.
FWIW I run a Push shock on mine. A 65mm stroke has clearance & takes it to ~170mm rear travel.
Yes! This is what I'm feeling!Guys with the coil shock do you feel like the suspension bottoms out to easily due to the shock being so linear? I have the Jade X and everything is great on it but i hit some chunky high speed trails and it almost seemed like it was to low in the travel to often? could just be in my head or how the Ebike rides
It was set up by the local importer/tuner who weighs the same as me so he knows the tracks I ride. I will contact him tomorrow & see if he has any recommendations.Maybe you need a heavier spring. Have you tried TF Tuned calculator?
I'm not getting this at all. On that terrain it's so much smoother than the air shock it's almost unbelievable.on rooty & rough rocky trails it seems to buck a fair bit
Taking into account that system is progressive enough, a coil shock in my opinion is always far better than an air shock,in terms of performance.
Better mid support,rear end is glued to the terrain etc. Definitely if you are bottoming out too easily,you need a heavier spring.
FTFY, Frenchie.other than the brakes being the right way round so almost died a few times.
Eeets is too keep you on your toooes ! ?! or head ...Seriously, why do you lot run the brakes that way round? Are your motorcycles cack-handed too?
@Doug Stampfer the sag option choice is a considering factor of the equation as well.
I've shamelessly nicked this idea and come up with a MK2 version that bolts straight onto the lower trunnion mount....I wanted to fit a Super Deluxe, so I made this yoke to lenghten 205 trunnion to 230. Works good.
Interested in selling one of theses yoke?I've shamelessly nicked this idea and come up with a MK2 version that bolts straight onto the lower trunnion mount....View attachment 51411
