couplands
Great question, I'm in the same boat and would really like a sync feature...?Is there a way to sync devices with Blevo? I sometimes use different phones....
Great question, I'm in the same boat and would really like a sync feature...![]()
You could check here..Ok sorry to hear that, I thought you were an app developer, my mistake ?
To that end, please could you make it clear which features are available on which platform as I'm sure others will want to know this before they purchase.
If you have Android, you can use the backup and restore functionality... do you know it?Great question, I'm in the same boat and would really like a sync feature...?
I have used it, but if I recall correctly it doesn’t sync both sets of data on both phones. I replaces the data from one to another. Is that correct..? If so, I would like a true sync...but understand it may be hard to do.If you have Android, you can use the backup and restore functionality... do you know it?
I just released BLEvo version 3.7.3 for Android. In a few hours it will be available on Google Play.
Now if you have 2 Specialized bikes, BLEvo will automatically recognize the one you turn on so you no longer need to scan every time you decide to go out with a different bike. Same goes for the old models that use 2 batteries.
On the home screen, always wait for the blue dot and you will see which BLEvo founds and which one it will connect to.
Another important news is the addition of the cardio zones of which I am attaching a screenshot.
To configure the heart rate threshold, go to the Smart HR configuration.
Here are all the news:
- Added cardio zones
- Now the first recognized bike is connected without having to go to configuration and re-scan
- Added configuration to enable / disable GPS ascent calculation correction
- Now the GPS ascent calculation correction can be made for each single tour
- Bugfix: voice message on GPS ascent
- Bugfix: resizing bike monitor fields
- Bugfix: off-track signaling on GPX with widely spaced points
- Bugfix: now the cursor does not rotate if the option not to rotate the map when stationary is activated
- Bugfix: correct display on 2 lines of the Smart Level and residual autonomy
Updated from Google Play ..
Enjoy your ride with BLEvo.
My BLEvo with iOS has always recognized my two bikes. Works perfectly.will there be an Ios update that will recognize two bikes soon?
Thanks Paolo
Data replace from one to another is the meaning of sync...at the end both have the same data...I have used it, but if I recall correctly it doesn’t sync both sets of data on both phones. I replaces the data from one to another. Is that correct..? If so, I would like a true sync...but understand it may be hard to do.
I'm sure it is... the 20 and 21s are basically the same bikeis the BLEvo app compatible with the 2021 Levo?
Mine did but now it takes some effort.My BLEvo with iOS has always recognized my two bikes. Works perfectly.
My idea of sync is two way. Both phones add their data together and yes, they are the same. If I have 20 rides on one phone and 70 on another, when I sync I expect all 90 rides on both phones.Data replace from one to another is the meaning of sync...at the end both have the same data...
The current solution is a backup and restore function. It will wipe any existing data on the phone that you restore the backup to.
In my example above, depending which way you did the backup and restore both phones would either have 20 rides or 70 rides and the others would be lost.
I want to combine - sync - both phones together so I dont lose any rides.
I do this with all my map data. I use OneDrive and OneDriveSync. I create routes on my PC or iPad then put them in my BLevo/Trails folder and then BLevo picks them up on the phone. Seamless.Thats really easy to implement on both iPhone and Android, both Apple and Google
provide frameworks to easily write information to iCloud and Google Drive; BLevo could just write the relevant data using those and then read from any device.
Paolo - I know you said you aren’t a developer, but you can pretty much copy and paste the code into BLEvo.
Thanks McInner1, not quite the same problem, although I've suffered from inaccurate speed / distance with the Bolt as per many posts elsewhere on this forum.This post seems related to your problem:
Probleme mit Wahoo Elemnt i.V. mit BLevo am Levo (2018) - sonstige(s)
Servus, bin vor ein paar Tagen vom Edge 1030 auf den Wahoo Elemnt Roam umgestiegen und soweit vom Gerät begeistert! Funktioniert top mit Komoot, Strava und den vorhandenen Garmin-Sensoren. Nun habe ich aber ein Problem beim Nutzen vom Levo als E-Bike-Sensor für Geschwindigkeit, Trittfrequenz...www.pedelecforum.de
If you don‘t speak German, use for translation: DeepL Translate
In the Garmin Forum they claim the opposite!Really wish I'd gone for a Garmin rather than a Wahoo, it just hasn't played nice from the start ?
Haha, and never the twain shall meet!In the Garmin Forum they claim the opposite!
