Ebike field works perfect on our Garmin edge 1000 with 2 Levo SL. I used the App management section under Garmin connect to set the battery ID to zero. Garmin found new bike and reports battery and field level.
Hi.
I got an SL and a Levo. Ebike field works great with my Levo (also installed a new battery yesterday and worked immediately). Edge 1000 computer.
But, is it possible to also get the SL connected? Only use one bike at the time of course..
Or do I need to setting the ID to zero and reconnect to a "new" bike every time I swap bikes?
Works fine here, on my vivo 3, I'm just not getting speed anymore, but I dont care about that.How about the Range Field? It shows 1.00km in my case, not changing at all.
Cheers
Has this been figured out yet for the Levo SL? Anyway of the main battery and extender being read?Yep it is correct. Based on current info, extender battery is reported on different place which Ebike Field currently doesn't read. Didn't have time to analyse this more yet, but it will for sure be possible to make it work also, so keep me finger crossed.![]()
You will just need to set it up once. The app stores one battery in the main section and the other below in a separate field. I find that the one that is stored in the lower section takes a few extra seconds to pair but always does.
Hello everyone! I have a turboclebo comp 2018 and danieri a garmin 830. until the other day I used an edge 1000 explore with iq "Specialized" and I only found the cadence and power sensors. Now instead the edge 830 finds as sensors "speed", "power" and a tall sensor called "specialozed" that I don't know what it is. then it is normal that using the speed sensor when I stop it still indicates speed of 5 or 7 km / h for a few seconds? Thank you all!
Hello Thomas, i have a Haibike 2019 with Yamaha PW-X system, 250W motor. Do you believe that i'll be able to see power, cadence and speed in the Garmin Edge 830 ? Do i need any Garmin app in order to display this data, or they will be displayed automatically when Garmin Edge 830 will be connected automatically to Yamaha PW-X motor?@dan3344 good point. At the time I had the PWX it did not transmit any other data then power, cadence and speed, and that were the only ones I captured with my Garmin (without IQapp). The battery juice left was displayed as bar on the build in Yamaha display (integrated in ahead)
or you could select it to be displayed as number in die second row (instead of ODO,...)
Your Edge has ANT+ ! And Jan Capeks IQ app works via ANT+.I just bought a Levo, and saw your app and jumped on a Garmin Edge explore 820.
It comes from power sensor. He reports both, power and cadence!For some reason it still captures Cadence (not estimating, actually capturing) so goodness knows which sensor is reporting that as the Cadence sensor is disabled!
I assume we are speaking about ebike field from Jan CapekOk, in theory I downloaded the app to the Garmin, I do not get the bike until Thurs. How do I pair the edge with the bike? Then how do I run the app on the Edge, I did not see it on the edge?
Ok, got it set, So it is only one data field? When I set it in the menu it says it will give me two data items, Battery and power mode, I take it they will appear side by side in the data field I choose? Also, any idea what I need for my Garmin to display Cadance?I assume we are speaking about ebike field from Jan Capek
Connect IQ Store | Watch Faces and Apps | Garmin
Add creative apps, watch faces, music and more to your Garmin devices with the Connect IQ Store app.apps.garmin.com
It is not an app but a datafield. If you have downloaded it from the IQ store and it was installed on your device you have to set it on one of your datascreens like any other datafield.
Press and hold the desired field where you want to set it on until the field gets a black border. Tap and a list opens. Scroll down to the group of IQ datafields. Go in and chose ebike field.
To pair the field simply hold your Edge near the turned on Levo.
Nothing special!Also, any idea what I need for my Garmin to display Cadance?
Ok, do I do that in the garmin connect or on the edge? Do I have to download an app from Garmin for that?Nothing special!
Connect your Levo as powersensor to your Edge 1030. You‘ll get then power and cadence.
It‘s a simple job on your Edge - nothing else needed:Ok, do I do that in the garmin connect or on the edge? Do I have to download an app from Garmin for that?
How about for cadence? Same?It‘s a simple job on your Edge - nothing else needed:
1 Bring the device (Edge) within 3 m (10 ft.) of the sensor (Levo).
NOTE: Stay 10 m (33 ft.) away from other riders' ANT+ sensors while pairing.
2 Select Menu > Settings > Sensors > Add Sensor.
3 Select an option: Power
4 Levo will be found.
5 Select Add Sensor.
When the sensor (Levo) is paired with your device, the sensor status is Connected.
You can customize a data field to display power.
see Page 16
Connect power and cadence is included in power. No need to connect cadence in addition.How about for cadence? Same?
Thank you!!!Connect power and cadence is included in power. No need to connect cadence in addition.
...and yes, for speed it is the same procedure.![]()
