Status
Not open for further replies.
PaoloBLEvo
Trader
Jun 13, 2018
1,449
1,184
Varese
Well I guess it depends on what you do with your bike. Sure you shouldn't be doing backflips off a cliff with this mount, but for normal Trail use it will do absolutly fine. And by mounting it backwards your phone sits on the inside of your handlebars and directly over the stem, so it is not as vunerable as sitting in front of the handlebar. I actually tested this on the first ride, my handlebar got snagged on the picket fence of our local cemetary, tore me right around and on my ass. Phone went flying, but didn't break, mount was ok, too. Only thing that went was my pride from the scowling glances the two elderly ladies gave me.
Thanks for clarification..
I think that for trail for "Kenevo" it is better the Lixada Gub holder.. not so beautiful like quadlock but stronger..
20,502
Apologize, I did not see on my mobile that it was Paolo himself.
Both which phones people use and equally, which mounts, are both fairly intrinsic (unless you just use it for stats or have the voice information on and stash your phone in your pocket) for a large part of Blevo's functionality, so are relevant to the thread. Paolo has made several posts in the thread about different phones and mounts.
Mesut
12
West Sussex
I run Blevo on my main (only) phone, a Oneplus 6T using this bag mount. It works really nicely for me and avoids the judder that I get with rigid handlebar mounts. Plus I can carry some tools, glasses, snack bar, etc as well.
Timbolot
10
Stuttgart
Hi there!
One question about the Apple Watch Integration to use Smart HR:
I tried it today and the readout said I had a flat pulse curve of 67bpm - so definitely correct ^^
How often does Blevo check the Apple Watch HR?
Just food for thought: When I use Zwift the Zwift Apple Watch App gets started automatically to get a good HR reading - is something like this maybe planned too?
Thank you :)
ca/nv/utemtbiker
Nevada/utah
just started having problems with blevo. I just upgraded to v3.6.6. I am losing connection to bike and motor during my ride. Sometimes I only lose connection to bike power, motor power and riding level. everything else is working. Today for the first time my screen went blank. I am using a blackview 5500pro with android. Up until this last upgrade. I had no problems with blevo. Any suggestion?
Jetpilot
26
22
Dorset
Sorry if this is answered elsewhere, i am trying to connect Blevo to my just bought 2020 Levo Comp, with android and am getting asked for a pairing code, tried 0000, 1234 as suggested but cant pair
PaoloBLEvo
Trader
Jun 13, 2018
1,449
1,184
Varese
If you lose connection with the bike try to update the firmware of the TCU. During the ride switch off and switch the TCU.. without touching BLEvo.. BLEvo will reconnect automatically.. It happened 2 times last week.. very strange.. The TCU Bluetooth connection is not so strong..
PaoloBLEvo
Trader
Jun 13, 2018
1,449
1,184
Varese
Hi there!
Thank you :)
@Stumpy could you help him?
Ed_M
25
27
Wokingham
The answer is in the user manual.
"You may be presented to enter a passcode on first connection to the bike. This can be found on a yellow sticker in your manual or written on the back of the TCU module. For older bikes it may be 0000."
PaoloBLEvo
Trader
Jun 13, 2018
1,449
1,184
Varese
The TCU code is under the TCU and it is 6 digits code.. The proposal from Android or iOS about 0000 code is wrong. The older bikes should not be paired with the phone.. only with BLEvo and/or Mission Control..
Drburns
35
41
Having trouble uploading to Strava. This is the first time this has happened. I’ve attached the error message I’m getting.
Timbolot
10
Stuttgart
Same for me....
Also I have the problem that Blevo crashes a lot (and stops to track my ride) and uses much more Battery on my iPhone compared to Mission Control
beutelfuchs
176
100
Barcelona
Hi @PaoloBLEvo
I can´t seem to get the smart power feature to work correctly.
What I want is to use e.g. 180 watts of my own all the time, the motor shall do the rest.
For that I use the settings shown below.
But what happens all the time is that the motor works way too much. Often I end up doing e.g. only 120 watts for a long time without the motor power tuning down.
BT connection to the phone is good, at least I can see my power and other status updates all the time.
Bike is a Kenevo 2020.
Do you have any idea what I could do wrong?
TomH79
322
304
Finland
Anyone has problems connectin to a bike?
2020 levo and iPhone 11. Takes multible efforts before it connects.
Baba
17
13
anacortes, WA
Thanks..
For heart rate from Apple Watch I'm studying a solution.. but I don't know when it will be available..
For Apple Watch monitor, I don't think that I will implement..sorry, but I'm developing in my free time..
Thanks for understand me.
Hi Paolo, really cools stuff. Do you say above that your app doesn't capture the heart rate from apple watch? So some other heart rate monitor must be used? Thanks!
PaoloBLEvo
Trader
Jun 13, 2018
1,449
1,184
Varese
Hi @PaoloBLEvo
Which tcu version you have?
PaoloBLEvo
Trader
Jun 13, 2018
1,449
1,184
Varese
With iPhone you can use the heart rate recorded by it.. just start an activity on the phone and configure it on BLEvo
Status
524K
