E7000
Shimano's 2018 mid-tier eMTB drive: 60 Nm and a deliberately gentle, natural delivery aimed at leisure trail riders rather than uphill racers. Lighter and quieter than the E8000 it sat beneath, it now lives on mainly in the second-hand market.
Classic older-STEPS shape: strong early support that holds best around 70-90 rpm, then fades as cadence climbs past roughly 105 rpm and drops away below 50 rpm. Shape is inferred from same-generation E8000 bench behaviour (GRAN FONDO); no dyno trace has been published for the E7000 itself.
Shimano E7000 was never built to win the torque war. Launched in July 2018 as the affordable sibling to the trail-focused E8000, it trades 10 Nm of peak grunt (60 Nm versus 70 Nm) for a softer, more measured power delivery that suits exactly the rider it was designed for: someone who wants assistance to flatten the climbs, not to be catapulted up them.
The character is classic older STEPS. Power arrives smoothly and predictably, the unit is light at an official 2.88 kg (DU-E7000 manual), and it stays comparatively quiet under load. Shimano never published a peak-power figure or an assist ratio for this STEPS-era unit, so the only honest numbers are the 60 Nm and 250 W rated figures; the often-quoted ~500 W peak and 300% assist are estimates borrowed from the E8000, not measured or official for the E7000. On the bench the E8000 family makes its best support around 70-90 rpm and fades away below 50 and above roughly 105 rpm (GRAN FONDO), and the E7000 behaves the same way: strong early, tapering as the cranks spin up.
Thermally it is an old-school STEPS unit with no published dyno endurance data, but in service it holds its modest rated output well on moderate climbs without the dramatic de-rate of higher-output modern motors. In 2026 the E7000 is a legacy proposition: it was superseded by the EP6 (DU-EP600) from 2022 and runs the Gen.1 battery and display ecosystem (BT-E8035 504 Wh / BT-E8036 630 Wh / external BT-E8014) that does not cross-shop with current EP-class hardware. For a used trekking or entry trail eMTB it remains a sound, low-drama motor; just don't expect it to keep pace with an 85 Nm modern Shimano, a Bosch Performance Line CX (85 Nm, up to ~750 W) or a DJI Avinox (105 Nm continuous, 1,000 W peak).
Character
The case for and against
Strengths
- Smooth, natural, easy-to-modulate delivery
- Light at an official 2.88 kg
- Quieter than the E8000
- Low pedalling resistance above the cut-off
- Plentiful and affordable on the used market
Compromises
- Only 60 Nm — modest by modern standards
- Gen.1 battery/display only, no EP-class cross-compatibility
- Discontinued; superseded by EP6 in 2022
- No officially published peak-power figure or assist ratio
