Bike Finder · Kona
no image yet
Kona
Remote 130 2024
DiscontinuedTrail eMTBLegacy · 0.7/10iFreshness 0.7/10
Motor
Shimano E7000 · 60Nm · 250W
Battery
Shimano BT-E8016 504Wh
Travel F/R
140/130mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£5,199
View the Kona Remote 130 on Kona’s site
Kona Remote 130 2024
From £5,199
EMTB Forums verdict
The Kona Remote 130 was the brand's mid-travel aluminium trail eMTB, pitched as a cross between the Process 134 trail bike and the bigger Remote 160. It ran 130mm of rear travel on a four-bar frame paired with a 140mm Fox Rhythm 34 fork, full 29in wheels and grippy Maxxis Minion DHF/DHR II EXO+ rubber. A slack 65 degree head angle, steep effective seat angle (around 76.5 degrees) and moderate 435mm chainstays across all sizes gave it a stable but lively all-mountain stance rather than a long, low enduro one.
It was sold as a single Shimano-equipped build. The drive system is Shimano's older STEPS E7000 motor (60 Nm) fed by a 504Wh internal battery, which is modest on both torque and capacity next to the 85 Nm EP8 systems and 600 to 750Wh packs that rivals were moving to. The rest of the kit is sensible and consistent: a near-full Shimano Deore 12-speed transmission, Shimano Deore brakes on 203mm front / 180mm rear rotors, WTB KOM rims and a TranzX dropper. Launch UK RRP was around 5,199.
The Remote 130 is now discontinued. Kona's electric trail range moved on from the E7000 platform, and the model no longer appears on Kona's site (its product page returns a 404). With its lower-torque motor and 504Wh battery it reads as an entry-to-mid eMTB by current standards, though the geometry and well-judged Maxxis and Fox spec keep it credible as a value used buy.
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm510 mm
Stack610 mm615 mm625 mm635 mm
Seattube385 mm410 mm450 mm485 mm
Chainstay435 mm435 mm435 mm435 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76.6°76.5°76.4°76.3°
Wheelbase1186 mm1213 mm1243 mm1282 mm
Headtube113 mm118 mm130 mm140 mm
BB Height345 mm345 mm345 mm345 mm
Standover720 mm720 mm720 mm725 mm
Front Centre751 mm*778 mm*808 mm*847 mm*
Trims · 1
Base
£5,199
MotorShimano E7000 · 60 Nm
BatteryShimano BT-E8016 504Wh · 504 Wh
Travel F/R140/130 mm
FrameAluminium
ForkFox Rhythm 34 Float 140mm Tapered 110 Spacing
ShockFox Performance Float Trunnion
HeadsetFSA No.57E
StemKona XC/BC 35
HandlebarKona XC/BC 35
GripsKona Key Grip
SaddleWTB Volt
SeatpostTranzX Dropper Internal 31.6mm
BrakesShimano Deore (calipers and levers)
Rear derailleurShimano Deore
CrankShimano E8000, 36t chainring
ShiftersShimano Deore
CassetteShimano Deore 10-51t 12spd
ChainShimano Deore
DrivetrainShimano Deore; Shimano E8000, 36t chainring; Shimano Deore; Shimano Deore 10-51t 12spd; Shimano Deore
WheelsWTB KOM Trail i35 TCS 2.0
TyresFront: Maxxis Minion DHF EXO+ TR 3C 29x2.5in WT; Rear: Maxxis Minion DHR II EXO+ TR 3C 29x2.4in WT
Price£5,199
Rides similarly
Spot a mistake?
