A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Remote 2023
The 2023 Kona Remote is the plainest, most honest member of Kona's e-MTB range: a full-power electric hardtail built around an aluminium frame Kona openly describes as being derived from the Honzo. There is no rear shock and no number in the name because there is nothing fancy going on here, and that is rather the point.
Power comes from Shimano's E7000 system, rated at 250W and 60Nm, fed by a 504Wh battery and managed through the SC-E7000 display. It is not the punchiest drive unit Shimano makes, but it is smooth, reliable and well suited to the Remote's all-day trail brief rather than to fighting for KOMs. The 140mm Suntour Zeron35 fork sits at the budget end of the air-sprung world, so expect competent rather than plush small-bump behaviour.
Geometry is sensibly modern without being extreme: a 66-degree head angle, 76-degree seat angle and a 320mm bottom-bracket height across all four sizes, with reach growing from 425mm on the S to 510mm on the XL. Chainstays stay fixed at 435mm and the 29in wheels wear grippy Maxxis Minion DHF and DHR II rubber, which flatters the hardtail's descending manners. The 1x10 Shimano Deore drivetrain, MT410 brakes on a 203mm front rotor, and a TranzX dropper round out a build that prioritises durability over weight.
As a hardtail it asks for a bit more line choice and forgiveness from the rider than its full-suspension Remote 130 and Remote 160 stablemates, but it rewards that with simplicity, lower maintenance and a genuinely fun, planted feel on flowing trails. For someone dipping a toe into e-MTB waters, or after a low-fuss machine for trail building and backwoods exploring, it makes a tidy case for itself.
Short 435mm rear and a lighter build — easy to pop, manual and throw around.
Balanced front-to-rear in L (FC:RC 1.83) — weight sits evenly between the wheels.
Climbs well — a 76° seat keeps the front planted. 250W of peak power and 60Nm of torque.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Lightweight · Cross-Country bikes (from 57 bikes in the database)
| S | M | L | XL | |
| Reach | 425 mm | 450 mm | 475 mm | 510 mm |
| Stack | 645 mm | 650 mm | 659 mm | 668 mm |
| Seattube | 385 mm | 410 mm | 450 mm | 485 mm |
| Chainstay | 435 mm | 435 mm | 435 mm | 435 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 76° | 76° | 76° | 76° |
| Wheelbase | 1175 mm | 1202 mm | 1231 mm | 1270 mm |
| Headtube | 115 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 320 mm | 320 mm | 320 mm | 320 mm |
| Standover | 739 mm | 736 mm | 734 mm | 734 mm |
| Front Centre | 740 mm* | 767 mm* | 796 mm* | 835 mm* |
| FC:RC | 1.70 | 1.76 | 1.83 | 1.92 |
Trims · 1
Remote | |
| Motor | Shimano E7000 · 60 Nm |
| Battery | Shimano 504Wh · 504 Wh |
| Travel F/R | 140/? mm |
| Frame | Aluminium |
| Fork | Suntour Zeron35 140mm Tapered 110 Spacing |
| Shock | n/a |
| Headset | FSA No.57B |
| Stem | Kona XC/BC 35 |
| Handlebar | Kona XC/BC 35 |
| Grips | Kona Key Grip |
| Saddle | WTB Volt |
| Seatpost | TranzX Dropper Internal 31.6mm |
| Brakes | Shimano MT410 Hydrualic (levers: Shimano M4100 Hydrualic) |
| Rear derailleur | Shimano Deore |
| Crank | Shimano E8000, 34t |
| Shifters | Shimano Deore |
| Cassette | Shimano Deore 11-46t 10spd |
| Chain | KMC X10 |
| Drivetrain | Shimano Deore; Shimano E8000, 34t; Shimano Deore; Shimano Deore 11-46t 10spd; KMC X10 |
| Wheels | WTB ST i35 TCS 2.0 |
| Tyres | Front: Maxxis Minion DHF EXO TR DUAL 29x2.6", Rear: Maxxis Minion DHR II EXO TR DUAL 29x2.4" WT |
Rides similarly
Spot a mistake?
