Bike Finder · Kona
Kona Remote 160
Kona
Remote 160 2024
DiscontinuedEnduro eMTBLegacy · 0.7/10iFreshness 0.7/10
Motor
Shimano E7000 · 60Nm · 250W
Battery
Shimano BT-E8016 504Wh
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£3,499
View the Kona Remote 160 on Kona’s site
Kona Remote 160 2024
From £3,499
EMTB Forums verdict
The Kona Remote 160 was the brand's value-led, longer-travel aluminium e-MTB, built to make self-shuttling gravity rides affordable. It pairs 160mm of travel front and rear with 29in wheels, a 65-degree head angle and a Kona 6061 butted aluminium frame, sitting above the trail-focused Remote 130 in the range.
This is a single-build bike at GBP 3,499, and the spec is unapologetically budget-conscious. Power comes from a Shimano STEPS E7000 motor and a 504Wh internal battery, the lighter-duty system in Shimano's range rather than the EP8 found on pricier rivals. Stopping is handled by four-piston TRP Slate EVO brakes on 203mm rotors front and rear, which is generous, while shifting runs Microshift's wide-range Advent X 10-speed. RockShox 35 Gold RL and Deluxe Select+ damping, plus Maxxis Minion DHF and DHR II EXO+ tyres, round out a sensible if no-frills package.
Geometry is steady and confidence-inspired for the era: 65-degree head angle across all sizes, 435mm chainstays, a 345mm bottom bracket height and reach growing from 425mm on the S to 510mm on the XL. It is more measured than aggressive, suiting riders who want stability for descending without a race-bred ride position.
The Remote 160 is discontinued. Within Kona's e-MTB line it sat as the affordable, longer-travel option, with the pricier Shimano EP8-powered Remote 160 DL above it for riders wanting more battery and a higher-end build.
💬 Forum discussion
Kona Remote 160
42 replies · 17.9k views · last reply 70 months ago
Join the discussion →
“Kona’s got a bike worth looking at. Definitely real Trail Bike geometry in keeping with their Process series. Not very many eMTB truly this progressive in the geometry. Rides great. Fits 27+ or 29 widetrail. Rides great! Shimano drive.…”
— sparrow · ♥ 6 · most-liked post
Bike geometry diagram
SMLXL
Reach425 mm450 mm475 mm510 mm
Stack615 mm620 mm629 mm638 mm
Seattube385 mm410 mm450 mm485 mm
Chainstay435 mm435 mm435 mm435 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)75.9°75.9°75.7°75.6°
Wheelbase1196 mm1223 mm1252 mm1291 mm
Headtube115 mm120 mm130 mm140 mm
BB Height345 mm345 mm345 mm345 mm
Standover743 mm759 mm755 mm770 mm
Front Centre761 mm*788 mm*817 mm*856 mm*
Trims · 1
Base
£3,499
MotorShimano E7000 · 60 Nm
BatteryShimano BT-E8016 504Wh · 504 Wh
Travel F/R160/160 mm
FrameAluminium
ForkRockShox 35 Gold RL DebonAir 160mm Tapered 110 Spacing
ShockRockShox Deluxe Select + Trunnion
HeadsetFSA No.57E
StemKona XC/BC 35
HandlebarKona XC/BC 35
GripsKona Key Grip
SaddleWTB Volt
SeatpostTranzX Dropper Internal 31.6mm
BrakesTRP Slate EVO 4-piston hydraulic disc, TRP Slate EVO levers
Rear derailleurMicroshift Advent X 10-speed
CrankShimano E8000, 34t chainring
ShiftersMicroshift Advent X 10-speed
CassetteMicroshift Advent X 11-48t 10spd
ChainKMC X10
DrivetrainMicroshift Advent X 10-speed; Shimano E8000, 34t chainring; Microshift Advent X 10-speed; Microshift Advent X 11-48t 10spd; KMC X10
WheelsWTB ST i30 TCS 2.0; Formula 110x15mm front hub, Formula 157x12mm rear hub, Stainless Black 14g spokes
TyresFront: Maxxis Minion DHF EXO+ TR 3C 29x2.5in WT; Rear: Maxxis Minion DHR II EXO+ TR 3C 29x2.5in WT
Price£3,499
Rides similarly
Spot a mistake?
